Need STAT Help - Switched Power Fuse
Jul 23, 2005 | 12:48 AM
Cruise-In III Veteran
Cruise-In IV Veteran
Prepping for the track and on my last hour -- all my switched stuff from the footwell wire just went down. I'm assuming it's the fuse, which one needs changed?
I have 6 hours to fix this and sleep...
Jul 23, 2005 | 01:38 AM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a B+ connection on each Fuse box. It is supplied directly drom the battery.
Here is apicture of the one in the engine compartment:
The Foot Well Box has a simular connection. Make sure that the B+ lug on each fuse box reads 12 VDC..
What are some of the things that you are missing?
BC
Jul 23, 2005 | 03:22 AM
FUSE FUSE FUSE
I know where to tap it and no time to rewire. I'm curious what fuse I likely blew from using the pass footwell acc power wire.
Jul 23, 2005 | 06:43 AM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That one is easy!
Mini fuse# 11 ASRY OFF (20A), and Mini fuse# 7 C/LTR (20A)
BC
Jul 24, 2005 | 08:16 AM
Quote:
Originally Posted by Bill Curlee
That one is easy!
BC
Thanks Bill! Both were popped, and we'd only found #7.
