Help... Found a Loose Bolt
Old Jul 23, 2005 | 05:39 AM
-X-'s Avatar
-X-
Default Help... Found a Loose Bolt
Ok... I kept hearing and feeling like something was hitting my driveshaft.. well C5's dont have drive shafts.. So I raised the car and found a bolt sticking out of the 3/4" hole where my Stall Converter Case is located. (rear of car)
The bolt was just loose.. and I pulled it out.. The bolt is around 2" long with a T50 torx head.. and its black..
Anyone know anything about this bolt..
Old Jul 23, 2005 | 09:50 AM
Patches's Avatar
Patches
Is it possible someone stuck a bolt in the TC access hole where a plug normally goes? I'm not as familiar with the A4 as M6 but it looks similar to this.
Old Jul 23, 2005 | 11:49 AM
-X-'s Avatar
-X-
Thats the hole it came out of... But, no i dont think its possible someone stuck it in there... I would have heard the bolt hitting the TC and all the moving parts alot sooner than I did..
X
Old Jul 23, 2005 | 12:40 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
That looks like it might be one of the bolts that hold the prop shaft in the torque tube, sounds like it might be time to drop the tranny.
Old Jul 23, 2005 | 02:00 PM
Patches's Avatar
Patches
Also, there are 7 M8x1.25x60mm bolts that hold the tranny pump in. Sounds like the size you are describing. As runamuk said, sounds like time to drop the tranny.
Old Jul 23, 2005 | 02:11 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The only reason I don't think it's one of those is because there isn't enough room for that bolt to come out with the torque converter installed but there is a ton of room between the flex plate/torque converter and the back face of the torque tube.
Old Jul 23, 2005 | 06:54 PM
-X-'s Avatar
-X-
Hmmmm
On the opposite side of the hole, where I found the bolt is an access panel (rubber boot cover). I removed that and looked... All the bolts that hold the TC to the Torque Tube are there...(at least it looks that way)...
Looks like the tranny will have to be dropped.. Just wish I knew for sure where this bolt was from..
X
Old Jul 24, 2005 | 07:26 PM
-X-'s Avatar
-X-
Does anyone have the diagram for these bolts.. It would be nice to see if this is the bolt..
X
Old Jul 24, 2005 | 08:42 PM
Patches's Avatar
Patches
(1) Torque Converter Assembly (Model Dependent On Size)
(2) Pump to Case Bolt
(3) Pump to Case Bolt O-Ring
(4) Oil Pump Assembly
(5) Oil Seal (Pump to Case)
(6) Pump Cover to Case Gasket
(7) Case Bushing
(9) Transmission Vent Assembly
(10) Oil Cooler Pipe Connector (Model Dependent)
(11) Case Servo Plug
(12) Servo Return Spring
(13) 2nd Apply Piston Pin
(14) Retainer Ring (2nd Apply Piston)
(15) Servo Cushion Spring Retainer
(16) Servo Cushion Spring (Outer)
(17) 2nd Apply Piston
(18) Oil Seal Ring (2nd Apply Piston - Outer)
(19) Oil Seal Ring (2nd Apply Piston - Inner)
(20) Servo Piston Housing (Inner)
(21) O-Ring Seal
(22) Servo Apply Pin Spring
(23) Servo Apply Pin Washer
(24) Retainer Ring (Apply Pin)
(25) 4th Apply Piston
(26) Oil Seal Ring (4th Apply Piston - Outer)
(27) O-Ring Seal (2-4 Servo Cover)
(28) 2-4 Servo Cover
(29) Servo Cover Retaining Ring
(30) Case Extension to Case Seal
(31) Case Extension (Model Dependent)
(32) Case Extension to Case Bolt
(33) Case Extension Bushing
(34) Case Extension Oil Seal Assembly (Model Dependent)
(35) Speed Sensor Retaining Bolt
(36) Internal Transmission Speed Sensor
(37) O-Ring Seal (ITSS to Case Extension)
(71) Filter Seal
(72) Transmission Oil Filter Assembly (Model Dependent)
(73) Transmission Oil Pan Gasket
(74) Chip Collector Magnet
(75) Transmission Oil Pan (Model Dependent)
(76) Transmission Oil Pan Screw
(94) Converter Housing to Case Bolt
(95) Oil Cooler Quick Connector (Model Dependent)
(96) Oil Cooler Quick Connect Clip (Model Dependent)
(97) Converter Housing Access Hole Plug (Model Dependent)
(98) Converter Bolt Inspection Plate (Model Dependent)
(99) Cup D4 Orifice Plug
(100) A/Trans. Case Stud (Y-Car Only)
(101) A/Trans. Oil Pan Plug Asm. (Y-Car Only)
(102) Converter Housing (Model Dependent)
(103) Main Section Case (Model Dependent)
(105) Servo Cushion Spring (Inner) (Model Dependent)
(106) Case Oil Seal Assembly (Y-Car Only)
(107) A/Trans Oil Pan Hex Head Plug Assembly (Model Dependent)
Old Jul 24, 2005 | 08:53 PM
Patches's Avatar
Patches
(1) Dowel Pin
(2) Access Hole Plug
(3) Propeller Shaft
(4) Bushing
(5) Plugs
(6) Snap Ring
(7) Bearing Housing Assembly
(8) Bolt
(9) Coupling
(10) Bolt
(11) Slinger Washer
(12) Snap Ring
(13) Bearing
(14) Input Shaft
(15) Bolt
(16) Coupling
(17) Bolt
(18) Bushing
(19) Plug
(20) O-Ring
(21) Dowel Pin
(22) Driveline Tube
Old Jul 25, 2005 | 07:53 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
(1) Dowel Pin
(3) Propeller Shaft
(4) Bushing
(5) Plugs
(6) Snap Ring
(8) Bolt
(9) Coupling
(10) Bolt
(11) Slinger Washer
(12) Snap Ring
(13) Bearing
(14) Input Shaft
(15) Bolt
(16) Coupling
(17) Bolt
(18) Bushing
(19) Plug
(20) O-Ring
(21) Dowel Pin
(22) Driveline Tube
Item 6 on some cars (I can't remember if it's older model or newer) has been changed to bolts.
Patches what year(s) is this diagram for?
Old Jul 25, 2005 | 08:27 AM
Patches's Avatar
Patches
True. That is for an '02. Since the poster doesn't list his MY, I pulled mine up. Here is one for a '98 which has the different tt setup. A buddy and I pulled one of these apart a couple of months ago to try and salvage the couplings. The bolts were a bear to loosen. They used a ton of loctite at the factory.
(1) Bolt
(2) Washer
(3) Dowel Pin
(4) Rear Bellhousing
(5) Access Hole Plug
(6) Propeller Shaft
(8) Bolt
(9) Washer
(10) Coupling
(11) Washer
(12) Bolt
(13) O-Ring
(14) Slinger Washer
(15) Snap Ring
(16) Bearing
(17) Input Shaft
(18) Washer
(19) Bolt
(20) Coupling
(21) Washer
(22) Bolt
(23) Bushing
(24) Plug
(25) Dowel Pin
(26) Driveline Tube
Old Jul 25, 2005 | 11:09 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Ok Thats it, the older cars had the bolts and I believe the changeover happened in 01 (like the other major changes). I tried to break loose one of the bellhousing bolts on a tranny recently (item 94 in your exploded view of the transmission) and I broke my torx bit thats how much locktight those have also.
The factory uses the locktite to ensure the bolts don't back out which is why I found it very odd that he found a bolt where he did and I'd be curious to know how many more are loose.
Old Jul 25, 2005 | 04:00 PM
-X-'s Avatar
-X-
Well the Trans has been dropped before, so I'm think'n that locktight might now have been put back on.. I just hope that none of the other bolts are loose..
X
To Help... Found a Loose Bolt
