Dual Zone Climate Problem
Old Jul 23, 2005 | 09:23 PM
Brady01's Avatar
Brady01
Default Dual Zone Climate Problem
I am having trouble with the temperature control unit on my 01. It's blowing cold air on the passenger side and warm air on the drivers side. Any suggestions as to what might be causing this?
Old Jul 23, 2005 | 09:27 PM
allanlaw's Avatar
allanlaw
Your driver side air mix door is not working. There can be many causes for this - door actuator (motor) shot (that was my problem), solenoid, etc., or you might just need to do a reset.
Old Jul 24, 2005 | 10:36 AM
Brady01's Avatar
Brady01
Default Reset?
By "reset" do you mean pulling the fuses in the passenger floor fuse panel (18 and 21 I think) and reinserting them? If so, I did that and still have the same result. If "reset" means something else, please let me know what that is and I'll give it a shot. Thanks for your help.
Old Jul 24, 2005 | 12:00 PM
corvette Mark's Avatar
corvette Mark
I am having the same problem with my 99. I disconnected my battery overnight ( approx 22 hrs) and when I reconnected the battery this morning my car still had retained all of its memory functions including radio presets and the a/c is still out of balance. Does anyone know how long I need to leave the battery disconnected to completely erase the memory and hopefully reset the a/c? I have been removing both the positive and negative leads from the battery.
Old Jul 24, 2005 | 02:37 PM
mrtoner's Avatar
mrtoner
I'm assuming you also have codes on your DIC.
If so, try this:
on the HVAC portion, reset each code individually
When you are clearing the last code, which should be the door actuator, wait 6 seconds and turn off the ignition.
Restart and check to see if the actuator is now set correctly.
I found that this "fools" the computer on the total stroke of the actuator, and it will work ok.
Old Jul 24, 2005 | 03:23 PM
ronwc's Avatar
ronwc
I had the same problem with my 98 and reset the doors a bunch of times which did not help - it turns out the systems was low on freon, which I had evacuated and refilled - works perfect now -
Old Jul 24, 2005 | 03:24 PM
corvette Mark
no HVAC codes. air temp is 60 degrees on passenger side and 80 degrees on driver side with the controller set to 60 deg on recirculate, passenger controller set to full cool.
Old Jul 24, 2005 | 08:10 PM
allanlaw's Avatar
allanlaw
You can do it by pulling the HVAC fuses or by disconnecting the battery - I prefer the former method. If that doesn't do it, then something in the system is broken. The dealer can find it with a TechII. Luckily, I had it fixed on extended warranty a few months ago. The dealer even had the air mix door motor in stock
To Dual Zone Climate Problem
