Door panel repairs!!
Old Jul 25, 2005 | 08:06 PM
no1g8tor's Avatar
no1g8tor
Default Door panel repairs!!
I tried to search for this but found nothing.
My 98 door panel covering is ungluing from top to the arm rest. Is there a fix for this. I check the price of new door panels and the are big $$$. Is this a common problem? If so where can I get new/Used ones at a decent price? Thanks. Mike
Old Jul 25, 2005 | 09:36 PM
VMI07's Avatar
VMI07
Same problem here. I have a 97 that was in the southwest heat. No fix today but I am working on one. I keep you posted.....
Old Jul 25, 2005 | 10:03 PM
RuberXCIX
Guest
Posts: n/a
TTT I would like to know a fix for this too, my doors were perfect until our heatwave here in PHX the last couple weeks.
Doug
Old Jul 25, 2005 | 10:07 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Old Jul 27, 2005 | 12:00 PM
no1g8tor's Avatar
no1g8tor
anyone with suggestions?? Does anyone have a good deal on some blk/grey door panels in near perfect condition, if so please pm me.
Old Jul 27, 2005 | 05:24 PM
kking1997's Avatar
kking1997
n01g8tor,
I wanted to let you know I had the same problem with my door panels and here is how I fixed them.
I have pewter interior with black door panels. I bought the accented arm rest from Ecklers which are padded in the pewter color. Then I took my car to a recommeded upholstery shop and they cut the material on the door panel arm rest. He then used a upolstery glue and roled the material down the way it was before it came loose. By cutting a slit in the material it took the pressure off and which allowed it to lay flat. He then put on the padded arm rest that I had bought. This actually look really good since it accents the door. I also purchased the matching door pulls as well. It looks better than it did when it was new.
The total cost for the parts and labor was around $200.00 which I am sure is cheaper than new or used door panels. I hope I explained it good enough. Sorry I have no pictures for you to see.
Good Luck
Old Jul 27, 2005 | 08:21 PM
no1g8tor's Avatar
no1g8tor
kking,
If i am to understand this...They cut the material on the arm rest and I assume that they reached inside the slit/hole and smeared the glue on the inside...then pressed the material down...then installed the arm rests. Is this right? Thank you for the info.
Old Jul 27, 2005 | 09:21 PM
towercontroller's Avatar
towercontroller
i think andy at Z06parts.com has some available, dont think they are all that expensive. I am close to needing some also
Old Jul 28, 2005 | 04:06 PM
kking1997's Avatar
kking1997
n01g8tor,
That is exactly what they did. This allowed the material to be glued down smooth and the door accent that I put on covered up the slit. This is the only way I could figure out how to do it without replacing the whole door panel. It actually worked out quite well and looks good.
I hope this solution helps.
kking1997
Old Jul 28, 2005 | 10:33 PM
newberd's Avatar
newberd
I have a 98 that has split right where my elbow rests. Happened this spring when the weather started getting hot. There must be a fix. Any upholstery guys out there that can help?
Old Jul 29, 2005 | 07:48 AM
gmosley's Avatar
gmosley
my local dealership is goodwilling me a new one for my driver door even though its out of warranty
Old Aug 1, 2005 | 01:42 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
The door panels on these cars aren't worthy of a Yugo.
Old Aug 1, 2005 | 01:45 PM
vetterlatethannever's Avatar
vetterlatethannever
Wow!!
Old Aug 1, 2005 | 07:52 PM
berryj's Avatar
berryj
You might try Gene's Kar shop, he usually has good deals on this stuff used. His link is on vendor ads here.
Old Aug 1, 2005 | 10:09 PM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
My 97 was bubbled a little when I purchased it so I bought a couple like new used ones off ebay. Mine are black and are not bubbled too bad. I would sell them cheaply if any of you would be interested. They are black in color. Send me an email if interested.
Old Aug 2, 2005 | 01:33 AM
Fasthotrod's Avatar
Fasthotrod
BINGO!! I got a set from Gene and they were perfect! Didn't cost as much as you would think, and I still have my old ones that I can "mod" for stereo stuff. Gene has what you need, and is GREAT to deal with!
Mark
To Door panel repairs!!
