GM oil consumption procedure?
Old Jul 26, 2005 | 03:37 PM
Hall1836's Avatar
Hall1836
Default GM oil consumption procedure?
Have a 2001 with oil problem at high RPM. What does GM deem as acceptable oil useage? For those of you who have had the GM ring fix, would you have done things differently (add oil) instead of having the motor taken out and apart? How does the oil consumption test by GM work? Thanks.
Old Jul 26, 2005 | 07:00 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The GM guidelines :
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
Verify that the engine has no external leaks. Repair as necessary.
Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
Park the vehicle on a level surface.
Wait at least 5 minutes (20 minutes for the 3.4 L LQ1), after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase.
Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
Record the vehicle mileage, date, and exact oil level on the form included in this bulletin.
Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption
Old Jul 26, 2005 | 09:57 PM
Hall1836's Avatar
Hall1836
Thanks, for the reply. I have approx. 11000 miles. If I drive easy I have used 1/2 qt ( a little more) in 2000 plus miles. All of a sudden when driving hard, have used as much as 1 qt. in 600 miles.
Old Jul 26, 2005 | 10:37 PM
Internets_Ninja's Avatar
Internets_Ninja
i noticed the same in my 2001 Z06. Driving normal and easy the car went for 1600 miles before using a QT of oil. THen I drove it hard for a period of time and i was 1 QT low in 600 miles. I havent taken it in for a re-ring because its a hassle. But I will get it in there shop before the extended waranty runs out.
To GM oil consumption procedure?
