Help Spinning Tick From Engine!
Old Jul 28, 2005 | 10:50 AM
nightmel's Avatar
nightmel
Default Help Spinning Tick From Engine!
You know the ticking sound you hear when a valve needs adjusted? This is the best way I can describe this sound, but it is n't quite as loud or does it come from the heads. It is very prominent from under the front of the motor and can hear it coming from under the car when hood is down as well as driving from cockpit. It gets faster and louder with increased RPMs,It is a 2000 Coupe,A4, with no Mods, YET! Buying and installing all at once. Anyone got an Idea? Thanks
Old Jul 28, 2005 | 01:25 PM
nightmel's Avatar
nightmel
Idea anyone, I think Harmonic balancer!
Old Jul 28, 2005 | 02:48 PM
Z51_6SPD's Avatar
Z51_6SPD
Check the belt. Could be a chunk out of the belt.
Old Jul 28, 2005 | 02:58 PM
ArKay99's Avatar
ArKay99
Does it tick in unison with engine rpm's or at 1/2 engine rpm's?
Old Jul 28, 2005 | 11:54 PM
1BAD-LS1's Avatar
1BAD-LS1
Maybe an exhaust leak? Check around the manifolds, or at the collectors.
Old Jul 29, 2005 | 04:25 AM
nightmel's Avatar
nightmel
I'm not real sur it ticks so fast that it is hard to tell. Why do you ask? Do you have an idea?
Old Jul 29, 2005 | 10:13 AM
nightmel's Avatar
nightmel
Had the car up on a lift and the ticking sound is coming from the crank pulley or the casing right behind it. But definitly from that region.
Old Jul 29, 2005 | 04:39 PM
jcgordon's Avatar
jcgordon
Default Ticking
Try the new Mobil 1 Extended Performance Oil. I had a noise like that and the new Mobil 1 oil stopped it but the old mobil 1 wouldn't. Amsoil will also stop the noise but Mobil 1 is easier to find and cheaper. Try that first before you start doing something costly.
Old Jul 30, 2005 | 07:04 AM
nightmel's Avatar
nightmel
I went from Mobile 1 to Red Line ,but the tick was there before I switched. I cant quite figure it out. I just hope it isn't my bearings!
Old Jul 30, 2005 | 12:04 PM
David426's Avatar
David426
You have piston slap, a very common problem with lots of GM engines. Its during the warm up period and goes away after that, most of the time.. Read more at www.pistonslap.com
Old Jul 30, 2005 | 09:03 PM
Dave68's Avatar
Dave68
Higher-flowing oil filters tend to help - try a K&N; it does tend to quiet things down.
Old Jul 31, 2005 | 06:35 AM
nightmel's Avatar
nightmel
WOW! I never knew that this was such a big deal. A Lot of Good info ther David426. Thanks for the insight. It's a bummer though, just ordered the AFR's from Jason at Texas-Speed and wonder if it is pointless to install until I get this repaired? Anyone with some experience out there?
Old Jul 31, 2005 | 06:37 AM
nightmel's Avatar
nightmel
Thanks Dave68! I'll give it a try. Do you have the same problem? And if so what have you done about it? Does it really hurt performance or just an annoyance?
Old Jul 31, 2005 | 07:23 PM
Dave68's Avatar
Dave68
It is really just an annoyance, but was most noticable when I parked between two cars. Although this K&N oil filter (and the Baldwin version as well) quiets the ticking noticably, it doesn't completely eliminate it. Using heavier oil will make it worse, so stick with 5W-30, 0W-30, or 0W-40 synthetic oils for best results.
Old Aug 1, 2005 | 06:57 AM
cenzo's Avatar
cenzo
MAke sure it isn't something simple like a deteriorated plug wire causing a spark jump to ground. Try looking at the engine running in the dark and see if anything looks abnormal.
Old Oct 31, 2005 | 03:40 PM
Ron Dittmer's Avatar
Ron Dittmer
I think my Corvette also has some form of piston slap. It sounds like a "quiet" diesel engine when starting it from an overnight park, but is less after an 8 hour park at work. After warm-up, all is very quiet.
It's a little annoying, only because I expected perfection paying that much money for a car. I figure if it ever got worse, it would be a good excuse to have Lingenfelter to their magic.
Ron
To Help Spinning Tick From Engine!
