Header install & miss fireing
Jul 30, 2005 | 09:14 PM
Just installed Dynotech Headers & now the engine service light is on & engine seems to be missfiring need help
Jul 30, 2005 | 09:21 PM
Check your wires again. Make sure they "snap" onto the plugs and coils. If the wires have a lot of miles on them they may need to be changed.
Jul 30, 2005 | 10:36 PM
header install
car has 31000 miles. how long does it take for the computer to reset itself for the headers? Mechanic seems to have left the rear O2 sensors loose. Need help
Jul 30, 2005 | 10:56 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Also check for any broken plugs. Some installers do not remove the plugs when installing headers = broken plug(s)
Jul 31, 2005 | 05:02 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
My $$$$ is on broken damaged wires...they are easy to break/damage when pulling off which is why I went with new wires after install and damage is hard to see.....I would say screw all the hassle and buy new wires....
Jul 31, 2005 | 09:00 AM
Cruise-In V Veteran
St. Jude Donor '04
Quote:
You should not notice any drivability problems with just headers and make sure all of the o2 sensors are tight.
Jul 31, 2005 | 11:38 AM
Quote:
and installed in the right holes....not crossed up
Jul 31, 2005 | 01:32 PM
Quote:
your exhaust sounds great. whats the setup?
Jul 31, 2005 | 02:52 PM
Quote:
Thanks.
Kooks 1 3/4 headers, 3" offroad X, to B&B PRT's. Stage II heads and a 230/236 cam also really help the sound.
Jul 31, 2005 | 09:05 PM
header install
Thanks Guys. Problem solved. Had burnt wires on one rear O2 sensor & my mechanic had all the O2 sensors crossed up. Thanks Pewter99 for that thought.
Aug 1, 2005 | 03:40 PM
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Glad you got it fixed...I did the same thing, had the O2's crossed up and caused cyl#1 to misfire.
