With 21,000 miles on my Z it was time to replace the original rubber. While the front tires were fine (or so I thought), the rears were down to the point that I was getting dirty looks from the auto inspection people -- into the tread wear bars. The worst of it was that the tires had become very prone to flats from any road debris. With no spare tire or jack -- well you all know how nervous that makes a Z06 owner.
The shocker came when the front tires were removed and the left one showed almost an inch width of cords running halfway around the tire on the inside edge. This was totally invisible to anyone, even the auto inspection guys during my annual. And it was all caused by a shift in the carcass of the tire, which surely must go back to the manufacture of same.
Unfortunately, I did not have a camera with me. There were two fellow Z06 owners in the tire store with me at the same time and I showed the offset of the tire casing to them. Perhaps they will chime in on this thread.
Word to the wise - you may think you have 4/32" of tread depth on your Goodyear Supercars and be showing the cords bigtime, as I was.
Be careful.
I know a guy on here with a C5 coupe who had both front tires worn to the cords on the inner edge. It was a camber issue, not a tire issue. His was covered under his new car warranty at the time.
My front GY SC's were worn on the inside and I replaced the enitre set set at 16K miles. I replaced them with the PS2's. The alignment was off only by a hair. I too was not able to tell the tires were in such bad shape until I looked at the tires during an oil change, when the car was raised.
Same with me...replace the whole set after over 17K miles. Both front tire are worn in the inside.
I bought my Z with the original tires on it and about 20k miles. The fronts looked the same with the cords showing on the inside of the tire. I just replaced them with Wide Ovals and kept rolling. I do need to get an alignment to be sure it was not that though.
OK, everyone who has left a comment so far has missed the point of this message. This is not about wear of the inside edge due to negative camber. This is about casing shift on one of my front goodyears that was so extreme that it was well down into the cords for almost half of the circumference and there was plenty of tread left on the other half of the circumference.
So it's about casing shift not negative camber.
It's about defective tire manufacturing, not wear.
As low as the Corvettes are, with all the overhang on the front, there is practically no way to see this without removing the wheels from the car.
I am sorry to have missed the point of your thread. If in fact the casing has gone bad... I would not ever buy another supercar tire again. I have had very good luck with Michelin Pilot Sports as well as BFG KDW's. Having run the MPS tires on the street and track for years... thats what I would be buying now if I were you.
Supercars are side specific, they cant be switched from side to side.
Remove the tire from the rim, flip it so former inside is now outside and mount it on the rim, this leaves the left front tire on the left front. Side specfic and directional.
Sorry Z.06, didn't realize this was caused by casing shift.
