Need Help On A 2000 Model
Old Jul 31, 2005 | 07:23 PM
Mrcorvette91's Avatar
Mrcorvette91
Default Need Help On A 2000 Model
A friend of mine is having a problem with his signal lights. They work intermittently. There are times when they work perfectly, and then the next time they may not work at all. Could it be the flasher? Anyone had this problem, or have any suggestions on a solution? Thanks all...
Old Jul 31, 2005 | 08:35 PM
STA-BLK's Avatar
STA-BLK
It is the flasher.My 2000 does the same thing.Hit the flasher a few times and it should clear it up for awhile.
Old Jul 31, 2005 | 08:40 PM
Kexec's Avatar
Kexec
Default Turn Signals
Replace the hazard flasher.
Old Jul 31, 2005 | 09:13 PM
Mrcorvette91
I was hoping it was the flasher...anyone let me know where the flasher is located? Thanks...
Old Jul 31, 2005 | 10:35 PM
STA-BLK's Avatar
STA-BLK
The button is the flasher.It is an all in one unit.And a pita to change.You must take out the cluster to do so i belive.
Old Aug 1, 2005 | 02:32 PM
robsvette's Avatar
robsvette
yeap mine is going too. i hit the hazard button and the turn signal begins to work again. doesnt happen too often though so im leaving it as is
Old Aug 1, 2005 | 02:52 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Got the extended warranty? Let GM replace it.
No? Be careful removing dash (sure way of getting to the switch) or from the outside (involves punching out the old one- seems risky when I read the instructions.)
Old Aug 1, 2005 | 06:07 PM
Scubanme's Avatar
Scubanme
HECK NO, you don't hope it's the flasher! They are not cheap, nor an easy install. Actually I need to replace mine also. I wonder who has the best price?
To Need Help On A 2000 Model
