Tranny Cooler
Old Aug 3, 2005 | 12:10 PM
maacoman's Avatar
maacoman
Default Tranny Cooler
Hi Guys,
I'm installing a converter and rear this weekend and want to know what tranny cooler to use,do they have any with AN fittings or is 3/8 hose with clamps good enough.Also should I eliminate it going through the radiator cooler and run it straight up..
John
yank SS 3600
3.42 rear
Old Aug 3, 2005 | 12:20 PM
kromberg's Avatar
kromberg
If you are going to use the radiator also, run the fluid through the external cooler first and then the radiator. Doing it that drpped my temps about 10 degrees in the tranny temps and 15 degrees in coolant campared to the other way.
If you have a large enough cooler and a small stall converter, you can eliminate the radiator one all together.
Keith
Old Aug 3, 2005 | 12:37 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I like my B&M cooler
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I just spliced the line an inserted the tranny cooler in series!!
Old Aug 3, 2005 | 01:14 PM
maacoman's Avatar
maacoman
Does the B&M have AN fittings or hose with clamps and how big should i go
Old Aug 3, 2005 | 01:29 PM
MR '02's Avatar
MR '02
Go with the B & M 24000 .......It comes with all the hoses and hardware to install and that it what I run on my '02 A4 with a 3.42 and a Yank SS3600.....Works great
I bought mine from Summitt Racing.....Best Price...Fast Ship
Old Aug 3, 2005 | 01:45 PM
kromberg's Avatar
kromberg
I have a 24000 B&M Cooler for sale. New $55 shipped with mounting hardware and hose if you are interested.
Keith
Old Aug 3, 2005 | 02:09 PM
Rag-Top Rick's Avatar
Rag-Top Rick
B&M offers several fitting and size choices, you can research them via their web site.
bmracing.com
Personally I`m running model #70264 (14,400 BTU) 24,000 gvw.
Ran aprox $60.00 at my local speed shop.
Rick
Old Aug 3, 2005 | 03:00 PM
Vette_Fan's Avatar
Vette_Fan
I'd get the B&M 24000, like some guys here suggested. Jegs.com is selling it for $50. My local shop is selling it for $45.
Does anyone know how hard it is to intall it? And what's the most effective way to use it, meaning - should it be put before or after the radiator, or totally by pass the radiator. I need some instructions.
Thanks...
Old Aug 3, 2005 | 03:27 PM
kromberg's Avatar
kromberg
Thanks...
In between the radiator and the A/C cooler. The feed line from the transmission should to connected to one end of the cooler, the other end of the cooler should be connect to the inlet side of the radiator. It is pretty easy.
Keith
Old Aug 3, 2005 | 03:55 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Thanks...
My B&M #70266 is a stand alone unit. Radiator is by-passed. They capped the radiator lines. They did not use the factory supplied hose or fittings, they used Russell fittings and steel braided line. Transmission temp with this install has dropped 40 degrees in this Florida heat. I had suggested an install with the radiator and my tuner said stand alone was better. After seeing these DRAMATIC results I tend to agree with him. Running the Yank SS3600 and the temp stays at 163 (it did go up to 165 once)
Bob
Old Aug 3, 2005 | 05:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What was the B&M's part # from summit
Old Aug 3, 2005 | 07:04 PM
SFVetteman's Avatar
SFVetteman
I believe the “B & M 24000” is the B&M 70264 (14,400 BTU 6x11x1.5), which is sometimes referred to as a 24,000 GVW cooler. Summit’s # is BMM-70264. It includes hoses, clamps, and adapters as well as everything you need to mount the cooler. If you prefer to use AN fittings and stainless steel braided hose then get the B&M 70273 Summits # is BMM-70273 and it doesn’t come with an installation kit.
A lot of people prefer the larger B&M 70270 (8x11x1.5) to drop temps down more. Summit’s # is BMM-70270 and it comes with the same installation kit as the 70264. For use with braided lines the Summit # is BMM-70266.
If you want to use braided lines you’ll need Summit’s SUM-G4990 mounting kit and these additional parts:
Note: Summit puts a prefix in front of the number (AER-)
(2) Aeroquip FCM2013 –6 AN to ½ NPT male adapter (cooler)
(1) Aeroquip FCM1022 –6 AN 45* swivel hose end (trans return line)
(2) Aeroquip FCM4032 –6 AN 90* swivel hose end (cooler)
(1) Aeroquip FCM4042 –6 AN 120* swivel hose end (radiator)
(2) Aeroquip FCM2108 –6 AN to 5/8 –18 inverted flare adapter (radiator & trans return line)
(1) Aeroquip FCA0606 –6 AN AQP racing hose, 6ft.
(1) GM # 442338 (or similar) 5/8 –18 inverted flare female union (trans return line)
Aeroquip website: http://www.aeroquip.com/pages/lit.html
B&M uses ½ NPT, female fittings on their coolers, others may be different.
It may be wise to cover up the steel braided line with some of that corrugated split plastic wrap as the steel braid can be very abrasive on whatever it contacts,
GM used the 5/8 –18 inverted flare fittings on transmission lines, through at least 2000 and probably later, then it was changed to something else but I can't recall what it is.
While many people choose to rout the lines a different way, I prefer putting the cooler between the stock cooler in the radiator and the return line of the trans. That way the radiator will help warm the fluid when it’s cold (which many say is a good thing, especially in cold climates) and the cooler can still bring it down to a good level, especially if it’s a 70270 or 70266 cooler
Old Aug 3, 2005 | 07:52 PM
maacoman's Avatar
maacoman
Thanks Guys
I ordered one from Summit #70264/24000 GVW.How do you guys have it mounted,and which line off the radiator goes into it. Sorry Keith if I would have seen your post I would have taken yours.
Old Aug 3, 2005 | 08:04 PM
SFVetteman's Avatar
SFVetteman
Disconnect the upper radiator line from the radiator and plumb it in there. Using the supplied mounting kit, it mounts on the AC condensor. The exact position is up to you and the length of the hose but I have mine mounted vertically on the left hand side
Old Aug 3, 2005 | 10:22 PM
screw991le's Avatar
screw991le
SF - Thanks for the info
Old Aug 3, 2005 | 10:34 PM
Cary's Avatar
Cary
Originally Posted by SFVetteman
Disconnect the upper radiator line from the radiator and plumb it in there. Using the supplied mounting kit, it mounts on the AC condensor. The exact position is up to you and the length of the hose but I have mine mounted vertically on the right hand side
According to the installation instructions, the preferred location is in front of the AC Condensor.
To Tranny Cooler
