1.8 ratio rockers
Old Aug 3, 2005 | 11:32 PM
vettes4fun's Avatar
vettes4fun
Default 1.8 ratio rockers
I have a 222/224 566/568 12 cam in my 97 would I gain anything by replacing my stock rockers to 1.8 rockers. Would I get more of a thump out of the cam and would it mess up my tuning that LG did for me. Any more Hp out of it.
Old Aug 4, 2005 | 02:40 AM
ramcharger's Avatar
ramcharger
depends on your heads, but you should see about 5% power gain. tune should be OK. you better have really good valve springs to handle the 0.600" lift.
Old Aug 4, 2005 | 05:48 AM
vettenuts's Avatar
vettenuts
Check the Cranes, they appear to be the better of the bunch. I am going the opposite as you, I plan on the Crane 1.8's and springs followed by a cam later. I won't go as high on lift as where you are going to end up though.
Old Aug 4, 2005 | 04:30 PM
FKING1's Avatar
FKING1
I run a similar cam with Jesel 1.8"s and .588 lift. Had to grind a bit of clearance in the rocker covers. As previous post, better change the valve springs and titanium keepers.Also high strength push rods.
Fred
Old Aug 4, 2005 | 05:04 PM
Laguna Blu's Avatar
Laguna Blu
If dyno numbers are all you are looking for then I'm not so sure that it would make a difference. See this post.http://forums.corvetteforum.com/show...642&forum_id=1
Old Aug 4, 2005 | 07:08 PM
XTrooper's Avatar
XTrooper
I have a lot of experience with higher ratio rockers. First I installed a set of SLP 1.85's on my motor and later replaced them with a set of the Crane 1.80 Quick-Lift roller rockers. The SLP rockers were a bit of a disappointment though I did pick up ~15 rwhp with them. However, when I replace them with the Crane 1.80's (actually 1.82) I picked up another 10 rwhp and 8 rwtq over and above what I'd gained with the SLP versions. Also, peak numbers don't tell you the whole story. I picked up gains across the entire power band with the Cranes and now have more power under the curve than ever before.
Old Aug 4, 2005 | 09:25 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
gain, yes. maybe a tiny bit of sound change. no, it will not mess up your tuning. now, seeing as you are at .566/.568 lift with 1.7 rockers, your new lift with the 1.8 will be about .605/.607 something to consider will be piston to valve clearance and the springs ability to handle the added lift.
Old Aug 4, 2005 | 09:32 PM
xxracerxx's Avatar
xxracerxx
I got a real seat of the pants improvement when I installed my Crane 1.8's!
Old Aug 5, 2005 | 02:20 AM
IFLUBYU's Avatar
IFLUBYU
As stated above this is going to put you at a total lift of just over .600, which means some decent dual valve springs. I highly suggest the CompCam 921's. From all reports, you should not have to modify your valve covers with the Crane's, they are a good choice.
Not an expert, just my $.02.... Good Luck!
Old Aug 5, 2005 | 07:31 AM
vetteamerica's Avatar
vetteamerica
I have the SLP 1.85 rockers and Comp 918 springs, very happy with my dyno number but the springs make too much noise! I may swap out the springs to Crane duals.
Old Aug 5, 2005 | 09:56 AM
Just Enough's Avatar
Just Enough
I did the Crane 1.8s with Crane Duals and feel a definate increase in pull under peak, have not dynoed it. It fattened up the middle rpm pulling torque of my Z which is what I was looking for. No codes, very slight increase in sewing machine noise at idle, fair amount of increase in exhaust tone which is cool.
Old Aug 5, 2005 | 07:11 PM
speedz06's Avatar
speedz06
I run 1.8's just be sure to change the springs use titanium retainers.and dont forget pushrods.Vinci high performance in Florida has an overstock of these kits so you'll probably get a good deal from Roger over there.he also has strong ties to Crane.I picked up near 20hp 20tq with a magcharged z06.I wonder how much valve clearence you have with that cam you run though.I run a stock z06 cam and my pistons have valve reliefs.Lastly,I have about 40,000 miles on the Cranes
Old Aug 5, 2005 | 07:28 PM
speedz06's Avatar
speedz06
Didnt realise that this subject is supported by TB I dont mean to suggest going somewhere else to buy parts when a vendor puts so much time and effort into a forum.Sorry Bout that Bro.Todd
To 1.8 ratio rockers
