Differential swap A4?
Old Aug 5, 2005 | 10:32 AM
EDJ's Avatar
EDJ
Default Differential swap A4?
How hard is it to swap out differentials in an A4? I'm going to be replacing my 2.73 with a 3.73. Any special tools, new gaskets or seals, can I do it by myself or will I need help? I have no lift, just jack and stands. Any insights or suggestions would be welcome. Thanks
Old Aug 5, 2005 | 11:09 AM
JSTAN's Avatar
JSTAN
Check out this site, lots of good info.
http://mikemercury.home.att.net/342.htm
For special tool, you will need a pry bar to seperate the TT from the bell housing and a tranny jack. I needed help from another person during removal and 2 guys when installing. Good luck with the project.
Old Aug 5, 2005 | 11:11 AM
EDJ's Avatar
EDJ
Thank you
Old Aug 6, 2005 | 08:24 AM
Mike04's Avatar
Mike04
Here is another link
http://www.corvettefever.com/howto/18978/index.html
Mike Mercury's page is great. Changing out the differential isn't that hard. As stated on his page, you can tilt the tranny down enough to swap it out.
Good luck
Old Aug 6, 2005 | 08:28 AM
Mike04's Avatar
Mike04
Just found this link,
http://www.cajundude.com/c5techhome.htm
Old Aug 6, 2005 | 09:26 AM
turbota's Avatar
turbota
Definately does not look like something a beginner should tackle all by himself IMO
Old Aug 6, 2005 | 10:34 AM
JeremyMSG's Avatar
JeremyMSG
If you have plenty of time, a pair of helping hands, and access to a lift, it may not be too bad. Not one to try solo on your back in the driveway with the car on jack stands for one of your first projects though
Old Aug 6, 2005 | 11:22 AM
b98's Avatar
b98
All you need is #1, a lift. #2, A big buddy. #3, one full day. go for it, have fun and go fast.
To Differential swap A4?
