Key Fob's
Old Aug 5, 2005 | 02:17 PM
batta bing's Avatar
batta bing
Cruising
Default Key Fob's
Has anyone had issues with trying to keep key fob's working properly? I replaced batteries, matched to car, set up appropriately, and then later when I go to lock unlock car, no action? Am I missing something?
Old Aug 5, 2005 | 03:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Take a look at your DTC codes that are stored in your DIC. I be willing to bet you a cold one that you have a TON of U-1000 series codes. That normaly indicates that your 12 VDC battery is weak and the reserve capacity inst there! When you crank the car the starter draws 200-300 amps and the voltage drops too low for the modules to function. This causes the sequence code to get wiped out in the BCM and RFA.
Read the codes and post what you find here. After you post them, clear all of them and monitor the DTC codes after you start the car!
BC
Old Aug 5, 2005 | 06:21 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
go stand by your car and hold down BOTH lock and unlock for like 10 seconds it should reset itself. Hope this helps
Old Aug 6, 2005 | 12:36 PM
batta bing's Avatar
batta bing
Cruising
Thanks I'll give it try.
Old Aug 6, 2005 | 02:13 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
let me know if it worked out for you
Old Aug 6, 2005 | 06:56 PM
Johnny5's Avatar
Johnny5
Also open up the fob and look at the upper right component. there have been a few members with this component cracking the 2 lower solder joints. If you resolder these it should work great again. I had this exact problem and once I resoldered I haven't had an issue.
Old Aug 7, 2005 | 05:59 AM
Villain's Avatar
Villain
To Key Fob's
