oil change question
Old Aug 5, 2005 | 05:34 PM
vet85's Avatar
vet85
Default oil change question
im going under 2 change my oil .any advise on the proper tool and size. ive heard alot of people say that the plug is very tight.and i would rather carry the right stuff the first time i go under the car .thanks for the advise.
Old Aug 5, 2005 | 05:56 PM
LoneStarFRC's Avatar
LoneStarFRC
If memory serves, it's either a 15mm or 17mm. Bring both. I use a six point box-end wrench and reach in from the driver's side. That way I can pull the wrench (not push) and get lot's more leverage. Just remember: "Righty Tighty" and "Lefty Loosey"
I use a pliers type oil filter wrench removal tool to loosen the filter. It partially crushes the old filter, but who cares? It's getting thrown away.
HTH,
Robert
Old Aug 5, 2005 | 07:33 PM
danberry's Avatar
danberry
Leave the 17mm in the box.............its a 15mm ..........I also like to raise the front end some and let it drain and then lower it back down and let it drain longer the better........
Old Aug 5, 2005 | 09:23 PM
vet85's Avatar
vet85
thank u job is finished
Old Aug 5, 2005 | 09:42 PM
LoneStarFRC
Miller time!!
To oil change question
