T1 bars and noise
Old Aug 5, 2005 | 10:33 PM
Phil97SVT's Avatar
Phil97SVT
Default T1 bars and noise
I have heard that the T1 bars are noisey, what makes them noisey and what kind of noises should you expect?
Phil
Old Aug 5, 2005 | 11:07 PM
SpeedyZ's Avatar
SpeedyZ
It is the T1 end links that are noisy. They are spherical rod ends and have a little slop in the even when they are new. When I say slop it is only .001-.002 of an inch but it is metal to metal. Many people say to just use the factory metal (not early model plastic) end links on the street and you will be fine. The T1 bushings look really good, they are hard rubber I think but have a woven cloth molded in which the bar slides/rotates against which should keep the noise down. They come in a pretty blue color and look to be power coated. I got mine from Fred Bean and I was NOT impressed with their shipping. GM shrink wraps the bar on a card board then puts it in a big box. FB opened and removed the bars from the cardboard and just stuck both bars into the same box with no other packing, except the head gaskets that I ordered! Yep, threw a set of head gaskets in the box with sway bars! For $120 shipping I was not impressed. Anyway the bars banged each other up pretty bad leaving several places where the pretty blue was knocked off.
Someone on the forum posted the part numbers for replacement rod ends that were not noisy. It was probably a year ago I seen that post, you may search for that and find better end links.
I can post photos of the T1 end links if you want to see what they look like.
Old Aug 6, 2005 | 06:53 AM
AU N EGL's Avatar
AU N EGL
When the T1 bars are propely instanded they are not noisy. The suppenssion must be set and ride height set without the bars connected. Once the ride height is set then the T1 end links are connected with the adjustable heim joint. No noise. Dont forget to lub the bushing. I just used a High temp grease vs carbon lubracant.
The noise comes when ppl adjust the ride height with the T1 end links connected and then they creek
Old Aug 6, 2005 | 07:21 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
no noise in 60,000 miles same end links I now track with.
Old Aug 7, 2005 | 03:34 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I run mine on the street all the time with no noise when they are adjusted properly
Old Aug 7, 2005 | 06:40 PM
ANTIVINUM's Avatar
ANTIVINUM
Mine sound like hell to. So are you saying that I need to just adjust the links in or out? And if so how do I know which way to go. I know I am kornfused.
Old Aug 7, 2005 | 07:15 PM
VetteSiNz's Avatar
VetteSiNz
Did you torque all the bolts....end links and bracket bolts?
Old Aug 7, 2005 | 07:19 PM
GR8-LIFE's Avatar
GR8-LIFE
Originally Posted by AU N EGL
wow, thats a thick-azz bar!
Old Aug 7, 2005 | 07:36 PM
MRIENG's Avatar
MRIENG
St. Jude Donor '09
5 k and no noise. Got to adjust them properly. But it is a little much for a street car. Got to get that thing out on the track to see the difference!
Steve
Old Aug 7, 2005 | 08:01 PM
AU N EGL's Avatar
AU N EGL
Blue is the the T1 38.5 mm, black is a '03 Z51, 26.5 mm. the 03 & 04 ZO6 front bars are 28.5 mm thick
ANTIVINUM what I would do is disconcont the Heim joint, end link from the A-arm, let your car settle a bit, check and if needed adjust the ride height, then ajust the Heim joint and reconect to the A-arm.
Old Aug 7, 2005 | 08:02 PM
AU N EGL's Avatar
AU N EGL
Do this with either a 1/2 tank of gas and your weight of something, I use 200 lbs of old rotors in the drivers seat. then do your adjustments.
Old Aug 7, 2005 | 10:49 PM
tcmc5's Avatar
tcmc5
The goal is to avoid preload on the bar by having the car settled on the suspension before adjusting and attatching the second endlink.
To T1 bars and noise
