radiator drain plug question
Old Aug 6, 2005 | 04:54 PM
gsxrjack's Avatar
gsxrjack
Default radiator drain plug question
I just installed a 160 degree thermostat and when i went to drain some fluid out of the radiartor the white cap just kept on turning without draining any fluid...i pried it out and the whole drain (small plastic pipe with oring on it) came right out easily and i drained the coolant that way....
now im worried that something might have broken off the drain and just pushing it back in might be a bad thing and im worried that it will shoot out under pressure, i just had the car all warmed up and took it for a high rpm run with no problems,
question is, has anyone fully removed the radiator drain on the radiator and does it just pop back in...
thanks
Jack
Old Aug 6, 2005 | 04:59 PM
Oldvetter's Avatar
Oldvetter
You broke it and need a new one. It only turns 90 degrees and you pull it out. You broke pins off of it.
Old Aug 6, 2005 | 05:07 PM
gsxrjack's Avatar
gsxrjack
thanks, thats what i was kind of thinking..glad i asked before i took it for a long ride ,,,,,,
can that piece be bought and is it a corvette only thing bought at the dealer, or can i find it at autozone etc......
Old Aug 6, 2005 | 07:00 PM
LoneStarFRC's Avatar
LoneStarFRC
I'm not sure if you really broke it or not. I'm wondering if when you turn it CCW 90 degrees, if it doesn't move rearward a bit on it's own. Kind of a cam action, and if you continue to turn it, it just rotates without loosening any more. I know that in order to get mine completly out, I used some small needle nosed pliers to pull it straight back and out (after turning 90 degrees CCW). In order to re-install it, you use your 1/4" drive nutdriver, push it straight in until it stops, then rotate CW 90 degrees. Unless you have loose broken pieces that came out or fell on the floor, you may not have really broken it at all. Check it out. HTH
Old Aug 6, 2005 | 07:10 PM
George8211's Avatar
George8211
That plug is a pain in the azzzzz
I could hardly turn the darn thing... I though I was going to strip
out hole on the valve. The plastic was flexing and bending.
Old Aug 6, 2005 | 09:03 PM
gsxrjack's Avatar
gsxrjack
ya, i broke off the little tab that fits in the slot...autozone and pepboys dont have them in stock but they do have them online, will order one monday from them after i see if the dealer or a local parts store has one in stock...
right now i safety wired it in so it cant come off so i can drive it..... :o
Old Aug 8, 2005 | 07:33 AM
gsxrjack's Avatar
gsxrjack
picked one up at a napa store on sunday...its in those "help" packages and the number is 61133 , the napa store was able to cross reference the numbers, in case anyone needs one, and this has a little hand tang so you can turn it with your fingers or a pair of plyers,,,,also the little tang is metal, not plastic like the one i broke off
Old Aug 9, 2005 | 05:00 PM
LoneStarFRC
And I'm sure it was waaay cheaper than a dealer's price would have been too!
To radiator drain plug question
