1999 spark plug change question ...
Old Aug 6, 2005 | 05:23 PM
swole29's Avatar
swole29
Default 1999 spark plug change question ...
how do you get the spark plug on the drivers side closest to the dashboard out of that tight place?
Old Aug 6, 2005 | 06:12 PM
Jay-rod's Avatar
Jay-rod
move the rubber hose out of the way,disconnect the booster line and use a socket that you can use a wrench on.(spark plug socket)
Old Aug 6, 2005 | 07:26 PM
Old Rotor Head's Avatar
Old Rotor Head
No here.
I have my wife do it. My hands are to big. She reaches in gets the plug out and a new one in about a minute. I learned this little trick after spending an hour trying. Oh, she great at changing turn signal bulbs too.
Old Aug 6, 2005 | 08:36 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just get a 90 degree knuckle. No need to remove anything, it takes 30 seconds.
Just the FRCs need to come off.
5 bucks at Sears.
Socket extension knuckle extension ratchet.
Just like that, you'll have zero problems on all the plugs.
Old Aug 6, 2005 | 08:41 PM
vettenuts's Avatar
vettenuts
I got the double jointed socket from Snap-On, works great. I think there is a tech tip on it.
Old Aug 7, 2005 | 09:26 AM
cowpunk's Avatar
cowpunk
I use a 1/2 inch breaker bar w/ a 3/8 drive adapter for the traditional 5/8 park plug socket to loosen. This combo is just the right length and depth to reach all the plugs. The I use use a 3/8 air ratchet w/ Snap-on flex extenstion to to fully R&R the plugs. I use a 1/2 torque wrench w/ 1/2 to 3/8 adapter and short impact swivel to re-torque. Last set-up is much tighter and AIR hoses do have to be moved/worked around to get good angle.
Best,
Jay
Old Aug 7, 2005 | 10:01 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
5 bucks at Sears.
The right tools really do the trick in this situation.
To 1999 spark plug change question ...
