lowering and alignment question
Old Aug 7, 2005 | 01:01 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default lowering and alignment question
I have a 97 vette wiyh the z51 suspension. If I lower it will it make much differance on alignment?
Old Aug 7, 2005 | 01:29 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
It would be best if you had it done. You're not guaranteed that perfect of an alignment from the factory anyways, it might be best to get an alignment regardless.
Chirs
Old Aug 7, 2005 | 08:46 AM
Dark-Knight's Avatar
Dark-Knight
Chirs
after 10,000 miles on my '04 and the suspension upgrades noted in my sig I sure needed an alignment.
Old Aug 7, 2005 | 09:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes,, you will need an alignment. It will most likely cause your tires to wear baddly in the inside edges If you have good tires now, you wont have them for long and if you have margional tires now, you will have bad tires even sooner.
BC
Old Aug 7, 2005 | 07:20 PM
VetteSiNz's Avatar
VetteSiNz
BC
Happens to me .... over 13K miles on the runflat.
Old Aug 7, 2005 | 08:46 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Sign up for Firestone's Alignment for Life program, so anytime you make any height adjustments you can take it back to have it checked/corrected again for no cost.
To lowering and alignment question
