Best Headers for a 99 FRC
if you dont use Kooks, your not using the best!
On a 346 up to 427 cu in, we have the most powerful Corvette headers on the planet. 346 cu in with 535 rwhp 482rwtq using out headers to power the fastest trap speed in america for a 346 normally aspirated engine in a Corvette.
And in the only drag race that these headers bumped heads in South Carolina, the LG headers took top honors.
Regardless;
Start with these features:
$1395 for the off road set comes with 3" x pipe and 3" rear pipes plus 3" off road pipes for that price. (Headers, X pipe and rear pipes) not just headers, and all stainless.
Then:
*** 304 stainless steel pipes all the way back to your mufflers. No cutting of your stock system.
*** 3" Merge collector. Same as used on our race winning C6 race car.
*** Full 3" X pipe that can either connect to 3" metal matrix cats or off road pipes made so you can change to and from cats easily.
*** full 3" pipes supplied to connect to your stock or aftermarket mufflers.
*** 32" primary tubes for good Low end torque. And the Merge collector and 3" X pipe system help the top end flow to achieve the same high rpm results as shorter headers while gaining in the low end where most people run on a daily basis.
*** Easy installation without any cutting and without having to lift the engine off the mounts.
*** Metal matrix cats flow almost double what ceramic cats flow. Metal cats lose about 4-8 hp while ceramic cats lose 10-14 hp. that is why we only use Metal matrix cats.
If there were a better all around design, we would make them and use them on our race car and call them LG PRo Long Tube headers. But we have the most hp and highest top speed at each race we go to.
The only improvement that we could make is to use $800 Burns stainless merge collectors which are not feasable for street cars because of their cost. We (Borla) build(s) our headers with a stamped Merge Collector so we could keep the cost down. The Merge collectors help scavange the exhaust to help pull the next cylinder's exhaust and thus help fill the chamber. It works.
I hope this helps clear the air.
Lou Gigliotti LGM
Plus the bonus of the ease of install over the Kooks.
Both headers are very well made, it really just boils down to your needs and or wants.
Good luck on your choice.
If money was no object....I would go LGs and my second choice would be Dynatechs for a C-5.
I love my LGs and have not had any other so I can only speak of the LGs. Something not posted is the support LG, Lou and his crew give. I can tell you from my personaly experiance, that LG has their act together, and are very proactive and customer oriented. Matt has been awesome with all my purchases and questions and have realy went the extra mile to ensure I got what I needed and fast.BLUFF (bottom line up front do we use that here?) I gained over 4 MPH and lost just over .4 with the only change being LG Pro LT and a tune. Same 60', same BFG DRs, and same sorry *** driver, ME
There is a great post about C5 specs and the weight of the headers is listed too, LG and the dynatech I think and the LG are 40lbs lighter I think? Great headers and I wish I would have done it and bought them as soon as I bought my car. Go for it! Dave
