Pinging and misfire
Old Aug 9, 2005 | 06:00 PM
candlewood's Avatar
candlewood
3rd Gear
Default Pinging and misfire
2001 Vette LS1 with Denso Iridium plugs, Donaldson Cold Airbox and filter, Bassani Exhaust system, OEM exhaust up to the x-pipe, 18,000 miles.
I have pinging under WOT above 3500 rpm when the outside temp is 85 degrees or higher. Also, I am encountering misfiring under WOT when the engine is hot. Engine starts and idles fine.
I plan on replacing the plugs with Bosch Platinum 4+ as the first step. Would this engine be running too lean? If so, where is there a Corvette Tuner in the 06784 or Greater Danbury, CT area? The dealer most likely will not be able to make any mods to the software.
I have noticed that other people have experienced this phenomenon and there is no real answer to this. Any assistance is very much appreciated.
Happy Cruising to all!!
Old Aug 9, 2005 | 09:02 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
It's all in the tune. A good tuner should be able to elminate all of your issues.
Old Aug 10, 2005 | 08:04 AM
George V's Avatar
George V
I live in the local area and don’t know of any tuners around. I used ECS in NJ, Chris is great at what he does. I don’t think your problem is a tune. I bet you have a defective knock sensor. Call one of the dealers, and ask they may point you in the right direction.
To Pinging and misfire
