Anyone get a P0336 code before???
Old Aug 9, 2005 | 11:49 AM
Ben01C5's Avatar
Ben01C5
Default Anyone get a P0336 code before???
Car won't start, so I had my dad check the codes. P0336 says it is the Crankshaft Position Sensor.
Could this prevent the car from starting? It cranks fine, just won't start.
Old Aug 9, 2005 | 12:26 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Crankshaft position sensor is where the ignition timing comes from so if it's bad your coils may not fire.
The sensor is located on the right side of the engine block above the starter.
Old Aug 9, 2005 | 07:10 PM
lost's Avatar
lost
It looks like this
Old Aug 10, 2005 | 10:32 AM
Ben01C5's Avatar
Ben01C5
Thanks for the info.
I am debating taking it to the dealer to let them check the codes and see if it is something they can fix, or having the car hauled to Norris/Next Level Performance in Orlando.
Old Aug 10, 2005 | 10:40 AM
98vert6spd's Avatar
98vert6spd
just go and buy the crank position sensor and replace it yourself
its probably a 10 minute job
and im fairly confident thats what it is
heres why
the crank positon sensor senses where the crank is in its rotation because at different points along its rotation the coil must fire to gnite the fuel air mixture in the combustion chamber
when a crank positon sensor goes out it will not notifiy the coil to fire any more because its not sending the signal
the symptom of crank but no start is exactly what will happen if this thing goes bad
your getting a code for the crank position sensor
thats about the clearest most cut and dry diagnosis you can get
71.88 at advance auto
GP Sorensen CSS278
Crankshaft Sensor
1 Year Replacement Warranty
Old Aug 10, 2005 | 11:43 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
GP Sorensen CSS278
Crankshaft Sensor
Whaa
Here's one from GMpartsdirect.com for $28 +shipping **edit** they won't link, just go there and look at part # 12560228.
And I have one brand new never opened that I'll let you have for $30 shipped to your front door.
Old Aug 10, 2005 | 01:12 PM
not08crmanymore's Avatar
not08crmanymore
Default no start
what little i know about mechanics,it's the crank sensor!
Old Aug 10, 2005 | 07:00 PM
ecudooberhead's Avatar
ecudooberhead
My car threw a P0335 code, which also refers to the Crank Positioning Sensor. After replacing the sensor (Damnit, I paid $71 from Autozone!) it still wouldnt start- turns out some of the wires that ran TO the sensor were melted due to touching my LT headers- replaced those and it was good to go
Randy
To Anyone get a P0336 code before???
