steering column locked-now what?
Old Aug 9, 2005 | 09:10 PM
pdd000's Avatar
pdd000
Default steering column locked-now what?
steering wheel locked. dealer said they fixed it long time ago. my car is stuck at work. anything i can do to unlock it???
Old Aug 9, 2005 | 09:21 PM
pdd000's Avatar
pdd000
did a little searching gonna try a few different thing. guess ill get the CLB kitt but didnt think i needed it cause gm fixed it. bull. if not this will be the second time the car gets towed from work thats if i can get the car out of the garage with the wheel locked in the straight position
Old Aug 9, 2005 | 09:35 PM
pdd000's Avatar
pdd000
it popped loose. hopefully i drive the car home without it locking up on the highway and i ordered the clb from thuderracing
Old Aug 9, 2005 | 11:13 PM
TEXHAWK0's Avatar
TEXHAWK0
I would also recommend you remove the lockplate and install the smaller plate that GM uses on the automatics. The Harness K kit has the relay harness that serves the same function as the CLB, and includes the smaller plate. That way, there is no chance the column can ever lock again. If the relay fails, which will cause the fuel to be shutoff by the BCM, you may have to replace the relay, but at least you are not having to try to get the column to unlock.
To steering column locked-now what?
