Short Throw Install
Old Aug 6, 2005 | 06:38 PM
Johnny5's Avatar
Johnny5
Default Short Throw Install
I'm going through the short throw shifter install and I can't get the center pin out of my old shifter. Is there a trick to getting that pin out that I should know about? I'm using cajundude's instructions (which are EXCELLENT btw). But there is nothing about if you can't get the center pin out. HELP!
Old Aug 6, 2005 | 06:43 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
It's been awhile but I believe the answer is taking a flat blade and hammer and banging it in on the edge of the center pin I think you will find the pin is shaped like a wedge of cheese and the hammer chissel routine works quite well otherwise it is a mfr for sure--tapping the flat blade will ease it out--
Old Aug 6, 2005 | 06:48 PM
ericdwong's Avatar
ericdwong
I used vice grips on the pin, then a large flat head screwdriver on a block of wood covered with a towel as a pivot point to wedge it out.
Old Aug 6, 2005 | 06:51 PM
Johnny5's Avatar
Johnny5
So I just tried to jam a screw driver under the center pin and using leverage and a hammer tried to pry it up. Still can't get the center pin to budge. Actually starting to deform the bottom of the center pin. I bought this car used, would there be any reason for the previous owner to have super glued/epoxied this pin in place?
Old Aug 6, 2005 | 07:10 PM
Avanti's Avatar
Avanti
The thing is called a "Demon Key or Pin" for a reason. As a used car, though, you've no idea what you've got. If the pin is damaged you will need to drill it out.
However, I got mine out by using a small Snap-On distributor/carb-wrench (small open-end with the open part turned to about 60-70 degrees or so to the handle), put something under the end as a fulcrum, hooked the open end of the wrench under the pin and simply levered it loose. No slipping and damaging anything or oneself as has been reported with other ways.
Good luck... it's well worth the trouble!
Old Aug 6, 2005 | 07:19 PM
Johnny5's Avatar
Johnny5
I'll see if I can't get one of those tomorrow. On a side note, say i just say f*** it, if I buy a new short throw boot, and shift ****, can i bypass the whole step of removing the stock ****? I was thinking about doing this anyway, I was just going to get the shifter installed first then decide whether or not I needed a shorty boot and new ****.
Old Aug 6, 2005 | 07:34 PM
MY1STPEWTER's Avatar
MY1STPEWTER
When I shortened my shifter I dreaded the thought of getting the demon key out. It really only took me a couple of minutes to get it out.
I first got a pair of needlenose visegrips and put them on top of the pin. Then get a screwdriver that will fit thru the gap in the middle of the needlenose. Then got a hammer and started tapping on the screwdriver from beneath, a little on each side and the key popped right out. Some people have used a touch of lubricant on the demon key but I didn't find it necessary to do so. Hope this helps.
Old Aug 6, 2005 | 07:44 PM
Patches's Avatar
Patches
https://www.corvetteforum.com/techti...D=34&TopicID=1
Old Aug 6, 2005 | 08:17 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
This is exactly how I got mine out! I also covered it with a towel just in case it decided to launch itself towards the windshield!
Old Aug 6, 2005 | 11:14 PM
FLL-Mike's Avatar
FLL-Mike
I used vice grips to grab it and hammered the vice grips in an upward motion and within 3 minutes it was out.
Follow Patches instructions. Short boot from Vette Essentials if you will be using a C6 ****.
Good Luck
Old Aug 6, 2005 | 11:25 PM
Johnny5's Avatar
Johnny5
Thanks patches, I'll see if I can't get ahold of some scrap wood tomorrow and try that. Of course I'm moving between places right now so most of my tools and any wood that I could cut up for scrap is in a storage space. Hopefully the big HD will be able to help me out.
Old Aug 6, 2005 | 11:37 PM
Dave68's Avatar
Dave68
This method has worked for me many times:
http://www.conceptualpolymer.com/corvette_install.htm
Old Aug 7, 2005 | 08:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
2 flathead screwdrivers pried down = pin out in 5 seconds.
Old Aug 7, 2005 | 04:11 PM
Johnny5's Avatar
Johnny5
So I've tried the block of wood/screwdriver leverage method with no results. I've tried the 2 flathead screw drivers and prying up at the same time and still this thing isn't budging at all. So what are my options? If I take it into a dealer, can I just have one of their techs get it out? Can I buy a new shift boot and **** and then just throw away the whole old stock assembly? also what aftermarket shift **** will work with the hurst shifter? will any momo work? thanks
Old Aug 7, 2005 | 09:27 PM
Dave68's Avatar
Dave68
Did you try this?
Get the right tool and you WILL get it out. By the way, any shift **** that works on an OEM shifter will work on the short throw.
Old Aug 9, 2005 | 10:22 PM
Johnny5's Avatar
Johnny5
Ahhhh finally, using the needlenose pliers and hammer I finally got the pin out and then about an hour later it was all done....ah it feels great. This is the first mod i've done for my car and I'm extermely happy with. Already looking at what I can do next to everyone who posted advice. It helped a ton.
Old Aug 9, 2005 | 11:15 PM
Dave68's Avatar
Dave68
Great news! The key (pun intended) is the impact, just the reason why impact drivers and hammer drills are so effective.
To Short Throw Install
