FAST Intake...HELP
Old Aug 11, 2005 | 09:53 PM
FULTILT's Avatar
FULTILT
Default FAST Intake...HELP
Just finished my h/c Z06, took it to Livernois to get tuned and they called and said the intake has a leak at the front of it where it meets the head. I followed the torque sequence like the instructions said and I replaced the valley bolts supplied with the intake. I did reuse my old gaskets, but the car only has 8,000 miles on it. Anyone heard of this?
Old Aug 11, 2005 | 10:57 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Don't reuse old gaskets, no matter how many miles
Old Aug 12, 2005 | 04:42 AM
Vegas Vette's Avatar
Vegas Vette
Old Aug 12, 2005 | 07:34 AM
see5's Avatar
see5
I do not think your problem is that unusual. First, some of the FAST intakes are just warped and will not seat. The torque specs do not allow you to bottom out the gaskets and they do loosen up frequently even with blue Locktite. I doubt it is the gaskets if they were carefully seated in the manifold. They are ~$50 o-ring type and are very resilient.
I am sure Livernois has seen this before.
Old Aug 12, 2005 | 08:25 AM
new vetter's Avatar
new vetter
Was anything taken off the head???
Old Aug 12, 2005 | 09:09 AM
Z06 Steve's Avatar
Z06 Steve
I reused my gaskets with 19,000mi and no problems.Fast intakes are hit or miss on the quality.
Old Aug 12, 2005 | 11:18 AM
slo-vette's Avatar
slo-vette
I would have enough for a second Fast intake if my gaskets were replaced every time the intake was off. The plastic o-ring gaskets are reusable. Check and see if the intake is warped.
Old Aug 12, 2005 | 04:12 PM
FULTILT's Avatar
FULTILT
Thanks guys, I am having Livernois check the intake for warping. Because I didn't buy it from them it's costing me a small fortune. For those of you who said not to use old gaskets, I have a friend who has had his intake off approx. 8 times without buying new gaskets, and without a hitch.
Old Aug 12, 2005 | 04:19 PM
see5's Avatar
see5
Let us know what comes of this?
Old Aug 12, 2005 | 04:38 PM
ArKay99's Avatar
ArKay99
My Fast was warped. I used new gaskets and torqued the manifold down from the middle to the outside in about 4 steps. I also went much tighter than the 89 in/lbs. the stock one says to use. I went to 18 ft/lbs. and used blue locktight. I don't know about FAST quality. They are really overcharging for what it is really worth. They are the only game in town for it though. You know what that means...
Old Aug 12, 2005 | 04:48 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
We ALL have friends that have done one thing or another.
In the grand scheme of things how much does the gasket "really" cost.
I would rather spend 20 bucks and KNOW that its not my gasket than save 20 bucks but have to spend 85.00 an hour to diagnose a leak.
FAST intakes are notorious for being warped. I would personally NEVER reuse a gasket of ANY kind.
Hope it all works out for you.
Old Aug 12, 2005 | 05:04 PM
shurite44's Avatar
shurite44
If you had replaced the gasket you would basically know if it was a warped intake manifold. Now there is some doubt. You have to admit that if there were no doubt you would not be asking the question. Gaskets are cheap.
Old Aug 12, 2005 | 05:09 PM
T_Vert's Avatar
T_Vert
Originally Posted by razor2430
these are o rings, they are reusable. I've reused mine on 3 different intakes about 10 times now w/o a single leak. If they look ok they will be fine.
Dave
Old Aug 12, 2005 | 05:29 PM
see5's Avatar
see5
I don't think you have seen these or are familiar with the problem?
And they ain't cheap.
Old Aug 12, 2005 | 05:44 PM
Z06 Steve's Avatar
Z06 Steve
no leaks here with only 50 in.lb per crappy fast instructions and loc tite.
Old Aug 12, 2005 | 05:47 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
50.00 gaskets on an 800.00 intake is cheap.
Theres an old saying for this: Tripping over dollars to pick up pennies..
Old Aug 12, 2005 | 06:28 PM
Scubanme's Avatar
Scubanme
To FAST Intake...HELP
Old Aug 13, 2005 | 01:49 PM
FULTILT's Avatar
FULTILT
Guys, the vendor I bought the intake from told me there was no need to replace the gaskets on an 8,000 mile car but I will let you all know what the final outcome is, and $50.00 worth of gaskets says it's NOT the gaskets. Any of you want to take me up on that? I was looking for input on warping and or if anybody went beyond the torque specs or if anyone had to exchange their intakes.
Old Aug 13, 2005 | 01:57 PM
FULTILT's Avatar
FULTILT
[QUOTE=ArKay99]My Fast was warped. I used new gaskets and torqued the manifold down from the middle to the outside in about 4 steps. I also went much tighter than the 89 in/lbs. the stock one says to use. I went to 18 ft/lbs. and used blue locktight. I don't know about FAST quality. They are really overcharging for what it is really worth. They are the only game in town for it though. You know what that means...
Old Aug 13, 2005 | 02:24 PM
shurite44's Avatar
shurite44
You brought up the gaskets in your first post??? I will refrain from posting next time I see your screen name. Good Luck.
I did reuse my old gaskets, but the car only has 8,000 miles on it. Anyone heard of this?.
