trans fluid change
Old Aug 12, 2005 | 08:23 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default trans fluid change
The trans fluid in the resoviur of my 01 Z06 is light brown, like really weak tea.
Should I change it?
how do I change it if yes??
the car has 47K miles original fluid
Old Aug 12, 2005 | 09:17 PM
silverz06vette's Avatar
silverz06vette
Maybe you are talking about the clutch fluid.
Old Aug 12, 2005 | 09:34 PM
Marlin's Avatar
Marlin
The fluid being light brown does not mean it is bad, it is automatic trans fluid (Dex III). It is probable ok, but would be better with a Mobil1 oil for protection and durability. Not sure how to do as I have only worked on Auto. But with most manual trans there might be a drain plug (low) and another plug to refill (high). maybe someone that has done it before can chime in. I think it holds 3.75 quarts
Just make sure, as silverz06vette was saying, that you are not looking at the clutch fluid which is NOT trans fluid.
Old Aug 13, 2005 | 10:11 PM
e-hodges's Avatar
e-hodges
sorry, :o duh
To trans fluid change
