Fluid leak! What is it?????
Old Aug 13, 2005 | 12:13 PM
viperZ06's Avatar
viperZ06
Default Fluid leak! What is it?????
Went for a little ride this AM and came back and parked the car in the drive while I cleaned it up. About 30 minutes late I pull into the garage and noticed a 5 inch circle of pinkish red fluid under the rear drivers side where it was parked. Appears to be dripping off the rear cross member. What is the diagnosis???? I have extended warranty thank heavens!
Old Aug 13, 2005 | 12:26 PM
ericdwong's Avatar
ericdwong
Sounds like tranny fluid.
Old Aug 13, 2005 | 12:34 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Another vote for tranny fluid.
Old Aug 13, 2005 | 02:07 PM
Vegas Vette's Avatar
Vegas Vette
Tranny fluid....
Old Aug 13, 2005 | 02:54 PM
David426's Avatar
David426
Its tranny fluid. I have noticed this on my too as of lately. I know there is a vent on the A4 trannys and it can burp out a little sometimes
Old Aug 13, 2005 | 02:58 PM
Mike Mercury's Avatar
Mike Mercury
did anyone say "tranny fliud" yet ???
Old Aug 13, 2005 | 03:20 PM
servohead's Avatar
servohead
let us not forget about the reddish color that the dexcool coolant has. A question for the topic starter might be, is this fluid oily or watery?
Old Aug 13, 2005 | 03:22 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
My dexcool is orange and it's at the front of the car not the back???
Old Aug 13, 2005 | 06:50 PM
viperZ06's Avatar
viperZ06
how do I know if burp up or bad seal?
Old Aug 13, 2005 | 07:38 PM
LoneStarFRC's Avatar
LoneStarFRC
Since you seem to have an MM6 tranny, it's most likely at the rear of the trans, where it mates to the differential.
Give it the sniff test. If it smells more like gear lube then it's probably the left side differential seal. HTH
Old Aug 14, 2005 | 08:58 AM
servohead's Avatar
servohead
oops my mistake, didn't see that he said the leakage was coming from the rear of the car! Hah!
To Fluid leak! What is it?????
