low oil
Old Aug 14, 2005 | 02:08 PM
BigMacNYC's Avatar
BigMacNYC
Default low oil
weird question- any comments welcome!! driving to work and the 'low oil level' comes on DIC. Make a long- short... I get home and check the level... its low. I add three quarts and recheck. Now the oil was above the fill line?!?!? So I am confussed.... what did I do wrong. I thought the oil was about 6 qts... pls leave comments....
Old Aug 14, 2005 | 02:14 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
If it was still registering on the dip stick, but below the 'normal operating area', 1 quart would have been sufficient.
Old Aug 14, 2005 | 02:26 PM
GR8-LIFE's Avatar
GR8-LIFE
3 quarts? Were you that low??? If not you overfilled. BTW, i think it takes closer to 7 than 6.
Old Aug 14, 2005 | 04:30 PM
Beezvette's Avatar
Beezvette
I have a 2001 and that year has some sort of funky dipstick which seems to be calibrated differently than earlier models, I'm not sure of 2002 on. With 7 quarts, the dip stick will read slightly below full. When the DIC warning goes on, you are slightly above the cross-hatch, and half a quart will get you about 2/3 of the way up, which is normal. If you added 3, you added way too much.
Old Aug 14, 2005 | 05:13 PM
BigMacNYC's Avatar
BigMacNYC
should I drain some oil???
Old Aug 14, 2005 | 05:32 PM
GR8-LIFE's Avatar
GR8-LIFE
Depends how much extra you have. On roadcourses I put in about 1/2 quart to a quart extra but I know I may burn some off too cuz of the intense envionment all day long. 1/2 - a quart wont hurt but putting too much more than that I have heard can cause issues. Perhaps someone can chime in as to what issues it could cause.
Rule of thumb when low on oil:
Add 1/2 quart, start engine and let cycle then check. If still low, add another 1/2 quart then check again and so on and so on.
Old Aug 14, 2005 | 06:57 PM
BigMacNYC's Avatar
BigMacNYC
if it only needs a quart or less why would the level be considered low???
Old Aug 14, 2005 | 08:19 PM
GR8-LIFE's Avatar
GR8-LIFE
if you are down a quart of oil that's just a tad low. ! quart and a half will be below the ADD line. But if you add 3 quarts to that now you will be way up on the stick
Old Aug 14, 2005 | 09:00 PM
Its_Go_Time's Avatar
Its_Go_Time
Overfilling your engine oil to this extent is BAD, BAD, BAD. It's really bad. If the crankshaft starts dipping into the oil, its gonna whip it up into a useless aerated foam which engine bearings don't like. Half a quart's ok, but not 3!
Old Aug 14, 2005 | 10:17 PM
JR_VETTE's Avatar
JR_VETTE
There's the key. Drain some of that oil off asap.
Old Aug 15, 2005 | 01:09 PM
BigMacNYC's Avatar
BigMacNYC
so I shouldnt of done anything....
Old Aug 15, 2005 | 01:15 PM
JR_VETTE's Avatar
JR_VETTE
If you're car is telling you low-oil, yes you needed to do something, but 3 quarts was way too much, especially if it was still registering on the dip stick. When in doubt, add a little, check it again, add a little more, check it again, until you're back up to the cross hatched section of the dip stick.
Old Aug 15, 2005 | 01:40 PM
GR8-LIFE's Avatar
GR8-LIFE
In the future add 1/2 quart at a time and recheck each 1/2 quart. Never dump 3 quarts of oil if you are showing low.
To low oil
