4:10 geer and speedometer question
Old Aug 14, 2005 | 03:48 PM
craig04c5's Avatar
craig04c5
Default 4:10 geer and speedometer question
How do you set the speedometer if you change the rear in a 6 speed? I am guessing I have to also purchase a programmer, and if so, which one would be best if this is the only reprogramming I need to make?
Old Aug 14, 2005 | 03:56 PM
FRCTony's Avatar
FRCTony
No changes necessary.
Old Aug 14, 2005 | 04:06 PM
lost's Avatar
lost
VSS [vehicle speed sensor] is on the axle, no change necessary unless you change tire diameter...
Old Aug 14, 2005 | 04:52 PM
craig04c5's Avatar
craig04c5
That's great thanks!
Old Aug 14, 2005 | 06:57 PM
Mike Mercury's Avatar
Mike Mercury
no programmer needed at all with you manual shift C5'ers (you lucky son-of-a-guns).
Old Aug 14, 2005 | 07:14 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
we are lucky
Old Aug 15, 2005 | 12:10 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
what about with the automatic?
Old Aug 15, 2005 | 08:56 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yep, synchros need to be programmed. Fortunately, I have a M6 so my 4.10s required no programming. Love 'em. Great mod!
Old Aug 15, 2005 | 11:14 AM
Mike Mercury
mvvette97; some of that is answered here:
http://mikemercury.home.att.net/342.htm
Old Aug 15, 2005 | 12:44 PM
craig04c5's Avatar
craig04c5
Anybody from South Florida know where I can get 4:10's or 3:90's installed and do I need to purchase a whole rear or is just getting the ring and pinion an option?
Old Aug 15, 2005 | 12:48 PM
Cajundude's Avatar
Cajundude
Yes, but you must have it installed by someone who knows the Getrag differential. It is unlike most diffs. Fortunately there is a place in Houston that does this so I took the diff out and brought it to them and then reinstalled it. $250.00 for setting the ring and pinion and an extra $50.00 for putting in both hardened shafts, new clutch pack, billet pinions support and HD pre-load springs.
Old Aug 15, 2005 | 12:52 PM
Mike Mercury
Very fortunate indeed. No place like that around me :
To 4:10 geer and speedometer question
