Alignment setup questions
Old Aug 16, 2005 | 10:07 PM
seattle's Avatar
seattle
Default Alignment setup questions
Last year I installed new Michelin ZP tires and had a 4 wheel alignment done. Ever since then the handling seems to be different. The car doesn't track straight as easily as it should. It does not wander on its own but the steering is really sensitive and twitchy almost like an old car with worn out front end parts. I have the spec's on how it was set up. maybe someone could give me some insight on this.
Thanks in advance!
Camber L/F -0.2 R/F -0.2
Caster L/F 6.1 R/F 6.5
Toe L/F 0.09 R/F 0.05
Cross camber 0.0
Cross caster -0.4
Total toe 0.14
Seback -0.11
Camber L/R -0.2 R/R -0.3
Toe L/R -0.03 R/R -0.01
Total toe -0.04
Thrust angle -0.02
Old Aug 17, 2005 | 12:30 AM
LS9's Avatar
LS9
for a stable ride, toe in the rear and run the front at zero toe.
works for me
Old Aug 17, 2005 | 10:10 AM
seattle's Avatar
seattle
Thanks, whiner.
Anyone else have more suggestions?
Old Sep 19, 2005 | 09:41 AM
Geno94's Avatar
Geno94
Don't suppose you have the readings before the alignment to coompare? My alignment man gives the before and after. Caster is a major factor in the car wanting to go straight ahead. Your caster may be a bit low. 6.9 on the left wheel and and 7.4 on the right wheel might be good caster numbers but it would be great to know what you now have. . Good luck!
Old Sep 19, 2005 | 10:25 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Thanks in advance!
Cross camber 0.0
Cross caster -0.4
Total toe 0.14
Seback -0.11
Total toe -0.04
Thrust angle -0.02
+0.14 total toe in front may be a bit high, even if it's in specs.check your outer edges for feathering. Honestly, the feeling you get may be coming from the Michelins, they should feel a lot different than the other tires you had on before. A degree higher on both side caster may help also. In my experience when test driving cars after I align them is that it takes at least ) 0.8-1.0 degrees to see and feel a difference. good luck
To Alignment setup questions
