Code P0410
Old Aug 16, 2005 | 10:09 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Code P0410
Help please...
My car, my dad and I just finished our journey from Seattle, WA to Charleston, SC and about 100 miles prior to finishing the trip the check engine light came on and the code was P0410 (Air Malfunction).
I called my buddy Paul (TALON90) and he told me it was a vaccum leak, so I am am going to investigate. There is a very slight whistling noise coming from the EGR area just in front of the driveside, so i an checking there. Any other ideas?
I did have the oil changed yesterday, but I can't think of anything down there that would have been knocked loose...is there anything?
Micah
Old Aug 16, 2005 | 10:12 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the air pump is unplugged or not working; located under dr. side front headlight area
Old Aug 16, 2005 | 10:14 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Thanks, I will check...
Another thing I need to add.
There is no (noticeable) performance loss with this, it is just annoying.
Old Aug 16, 2005 | 10:36 PM
SteveDoten's Avatar
SteveDoten
the ck eng light should be on w/ this code and you won't hear the whining noise upon startup w/ the motor inop(heats up cats by forcing air into the exhaust manifolds)
Old Aug 17, 2005 | 12:35 PM
SSTOZ06's Avatar
SSTOZ06
Cleared Mine And Never Came Back
Old Aug 17, 2005 | 01:04 PM
Z O SICK's Avatar
Z O SICK
I get the same gode all the time. I really need to check it out. What does it look like?
Old Aug 17, 2005 | 01:42 PM
TXNC5's Avatar
TXNC5
FYI, you can go here and get a breakdown of almost every PCM DTC code by year model.
As an example, here is the P0410 explained for a 2000 Corvette.
Most of the diagnostic processes listed require a scan tool that can turn on the AIR pump.
To Code P0410
