Optima Battery Hold Down Torque
Old Aug 19, 2005 | 12:02 AM
Shark Racer's Avatar
Shark Racer
Default Optima Battery Hold Down Torque
How much torque should I give this thing? I've had problems with my 75-25 red top coming loose and clunking. Obviously not a good thing.
I have the group 78 battery hold down. I've given it a LOT of torque, almost feels like too much. What's a proper value? (Am I using the right hold down?)
Thanks in advance,
-Steve
Old Aug 19, 2005 | 08:29 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Optima makes and sells a special hold down puck for their batteries. Go to the Optima web site for futher info. Good luck.
Old Aug 19, 2005 | 06:13 PM
VetteDawg's Avatar
VetteDawg
You don't have to tighten it with all your might.
Are you sure it's catching the bottom of the battery?
Old Aug 19, 2005 | 06:17 PM
LoneStarFRC's Avatar
LoneStarFRC
Especially the rear edge of the battery engagement in the tray.
Old Aug 19, 2005 | 06:41 PM
Patches's Avatar
Patches
A lot of folks miss that rear hold-down lip so the battery is not as ecure. Push down on the battery and shove it backwards toward the rear of the tray. It's a snug fit.
Also, here's a shot of the hold-down bracket I got from Optima.
Old Aug 19, 2005 | 09:50 PM
VetteDawg's Avatar
VetteDawg
Patches, you are the man.
I have the 34/78 Optima red......secured the same way.
Old Aug 19, 2005 | 10:01 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You don't need a special hold-down clamp with the 75/25.
The stock clamp works fine. Make sure the rear of the battery is tucked under the lip, the stock clamp wedges the battery into the rear channel and effectively holds the battery in place.
The special Optima clamp bracket shown above was made for fitting the larger 34/78 battery. It shouldn't be needed on the 75/25.
Old Aug 20, 2005 | 02:52 PM
Shark Racer
Thanks for the tips guys. I kept fighting with it - went over to my friend's house frustrated as hell. He noticed it was sitting a little high in the back. Whoops. Didn't have it tucked under the rear lip.
I felt like a total idiot.
Old Aug 20, 2005 | 02:58 PM
Patches's Avatar
Patches
Tom. Optima sent me the bracket for free and it gets a better bite than the stocker so I used it. The stocker worked fine for me as well. Here's a shot of it with my Red Top.
Old Aug 20, 2005 | 03:18 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Torque is not necessary, position is the key!
To Optima Battery Hold Down Torque
