Disappointing numbers
Old Aug 19, 2005 | 09:34 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Default Disappointing numbers
Had this installed and dyno tuned by Norris on my '02 Z06:
G5X-3 112lsa
AFR205 heads milled with 921 springs
flycut pistons
LSX 90mm intake
NW 90mm TB
160 stat
Already had LG headers, Corsa Ti race exhaust and Vortex intake. Result was 450 hp/383 tq. No reflection on Mike Norris, his reputation speaks for itself, but why the low numbers, especially the torque??? Any suggestions? Didn't do a baseline to compare unfortunately....
Old Aug 19, 2005 | 10:14 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
The torque does seem to be a bit low.. are you running cats? what compression are you running? How deep were the pistons cut ? what gaskets.. ? Gears ? I have a lot of experience with those combos and would like to help.
Old Aug 19, 2005 | 10:17 AM
dmtnt's Avatar
dmtnt
Thanks Chris! No cats, actually it's a straight through exhaust setup. LG headers, custom H pipe (X wouldn't fit), and Corsa Ti race system. Compression is 11:1, not sure on the piston cut and gaskets, will be getting the car back from Norris this weekend. Gears are stock Z06 (3.42?).
Old Aug 19, 2005 | 10:27 AM
SteveDR425's Avatar
SteveDR425
Yea your torque does seem low, because before I had the 402 LS2 put in my car, I basically had everything you did. However, I ran an X2 cam, Z06 TI exhaust, and High flow cats. I came out with 404 torque, and 433 RWHP. My ARF heads were also milled for higher compression and fly cutting was done.
Old Aug 19, 2005 | 10:28 AM
Cruise-In V Veteran
If its actually 11.1 compression it should be making a bit more torque. Sent you a PM
Old Aug 19, 2005 | 10:36 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Intake and TB to big possibly? Which intake manifold?
Old Aug 19, 2005 | 10:49 AM
new vetter's Avatar
new vetter
It's not the intake. It's good for at least 10 rwhp and 10 rwt over a LS6 combo.
Old Aug 19, 2005 | 11:12 AM
dmtnt's Avatar
dmtnt
Hi John, like new vetter said, the 90mm setup is good for 10+ hp over the LS6.
Old Aug 19, 2005 | 11:28 AM
johnsea06's Avatar
johnsea06
You know I'm no expert... but that hasn't stopped me before so here's my $0.02
Not all dyno tunes use the same standards... Norris uses the more conservative SAE. It's also friggin' 95F & 90% humidity this time of year in our neck of the woods!
I'm sure on another dyno using different standards you will get better numbers providing at least an additional 30-45hp. My prior #s were 373/372 which turned out to be more like high 330s or low 340s... after installing headers & pipes my SAE #s were 354/346 and after tuning 369/360.
...so turn that frown into a smile...
I promise I won't call you out if you claim 500HP...
Actually the real story is that your car is a POS and since I'm such a nice guy I'll do an even swap... well, on second thoughts perhaps you'll also need to throw in the trailer, CCW's and slicks since I've got the "racing stripes" paint treatment...
Old Aug 19, 2005 | 11:33 AM
dmtnt's Avatar
dmtnt
Well, I can understand your need for a trailer Crash....
J/K, I know Mike's dyno's on the low side too, but 30-40 hp/tq difference?? It doesn't matter to me all that much, my car is the furthest thing from a "dyno queen". The proof is in the putting! We'll see if I can get under 2:30 at Sebring now, but maybe losing the "ballast" would've gotten me there anyway!
Old Aug 19, 2005 | 12:05 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
I believe Mike's dyno is on the conserative side too. Your RWHP looks fine to me, but the tq does seem low by 20 or so from similar setups, but all engines are different.
Also, tuning in this temp will effect the overall numbers, but I personally WANT my tune done on a hot/humid day. Worst case the car will see! I want to DYNO on a cool/dry day for the BIG numbers.
I will be there (NLP) next Friday for my tune (see sig for mods) and I hope to be in the 410+ rwhp range and over 550 on the juice. We will see. Either way, Mike has always done a good job for me and my friends.
I wonder if your exhaust is doing something strange, seeing it is not a full LG system. That's the only "odd" thing you have compared to others.
Old Aug 19, 2005 | 12:17 PM
johnsea06's Avatar
johnsea06
FOUL!!! LOW BLOW!!! I guess I kind of set myself up for that one...
I went down 4HP after installation of the headers from a prior run so maybe more like 15-25 hp more conservative instead of the 30-40 I mentioned... not scientific but probably in the ballpark...
And I really don't think the weight of the "ballast" was the issue, probably more like the DDDistraction... everyone was complaining about your inconsistent line around the track that day (j/k)... and look at what the DDDistraction did to Fast Mike... poor guy... his last lap took over 30min and had an EMT escort...
Old Aug 19, 2005 | 12:22 PM
dmtnt's Avatar
dmtnt
You're right, that was low. :o Sorry, couldn't resist....
Maybe I'll stick her in the trunk with a stopwatch next time so I don't get DDDistracted!
Old Aug 19, 2005 | 01:54 PM
John Shiels
Some like it and some don't the Vette Doctors told me they found no real gain in stock CI motors. LG said about 10 as you stated. What did you expect or what do similar combos turn out?
Old Aug 19, 2005 | 01:56 PM
Cruise-In V Veteran
I have actually seen as much as 20 rwhp on a 346 head and cam car.
Old Aug 19, 2005 | 01:57 PM
John Shiels
Twenty HP would be worth it to me
Old Aug 19, 2005 | 02:10 PM
new vetter's Avatar
new vetter
Over an ls6? How big of cam?
To Disappointing numbers
Old Aug 19, 2005 | 02:28 PM
GR8-LIFE's Avatar
GR8-LIFE
yea, the numbers seem too much of a desparity even for DYNO differences. The thing is he's getting 450 hp! I would have expected a little more TQ, probably somewhere around 425-430. But then again, I know just as much as johnsea06 - well maybe a little more
Old Aug 19, 2005 | 02:53 PM
dmtnt's Avatar
dmtnt
I'm ok with the hp number, especially given Mike's dyno. The torque is definitely the problem. 425 would be great. I wonder if it's my exhaust, but I can't see how. 3" reduced to 2.5" at the H pipe, then straight through wide open! Maybe it needs some backpressure to get the tq numbers up?
Old Aug 19, 2005 | 03:02 PM
GR8-LIFE's Avatar
GR8-LIFE
You mean like a good fart?
