A4 trans 2nd gear
Old Aug 19, 2005 | 11:51 AM
billiardcue's Avatar
billiardcue
Default A4 trans 2nd gear
Is there a way mechanically or electronically to make an A4 trans use both 1st and 2nd gear when the shift lever in the 2 position?
Old Aug 19, 2005 | 02:55 PM
chaase's Avatar
chaase
St. Jude Donor '12
I know you can't do it electronically (I have asked), it is built into the valve body of the transmission. I am interested in this also, as 2nd gear start is of no use to me!
Chris
Old Aug 19, 2005 | 04:28 PM
Get a Vet's Avatar
Get a Vet
Boy, ain't that the truth!
Old Aug 20, 2005 | 02:18 PM
billiardcue
Does nobody have an answer for this question?
Old Aug 20, 2005 | 03:16 PM
lost's Avatar
lost
Why? There is no one forcing you to use it. It was designed that way for a purpose and that is to allow you a higher starting gear to negotiate ice or snow, if you don't need it , dont use it.I'm beginning to wonder if an IQ test shouldn't be required before you are allowed to purchase a Corvette.
Old Aug 20, 2005 | 03:30 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Old Aug 20, 2005 | 04:09 PM
billiardcue
Your response to the question is insulting and disparaging. I am under the impression this forum is a place for like minded enthusiasts to enter into intelligent discussion and learn from one another's knowledge. None of us have all the answers, if we did this forum would be unnecessary.
I fully understand the reasoning by GM as to why the transmission works the way it does but it does not suit my driving habits or desires and I would prefer to change it. This is no different than the thousands of other Corvette owners that modify their fine automobiles to suit their particular needs and or desires.
To clarify:
(a.) I solo 2 autocross and most courses require a shift to second gear and back to first one or more times during the run, life would be simpler if the transmission did this on its own.
(b.) My daily driving consists of many miles on winding mountain roads and second gear is my gear of choice for this type of driving. Having the car downshift to first on its own when I come to a complete stop again makes life simpler and I believe it is easier on the transmission if I fail to put it into third or first before I resume moving.
Thanks in advance to anyone with an intelligent answer to my question.
Dick Abbott
Old Aug 20, 2005 | 04:39 PM
JH's Avatar
JH
C'mon it's a legit question, and you gave a nasty-gram response. Get the hell out of here if you can't be more accommodating than that. I live in an area where the 2nd gear start is an asset, but I don't insult anyone who asks otherwise. That would be
Old Aug 20, 2005 | 04:49 PM
lost's Avatar
lost
Sorry if I insulted you, I told you why GM designed it that way. I use my auto like its a stick , also autocross, somehow I adjusted to this little quirk. wait till next year and the paddle shifted 6 speed auto, without a torque converter. That's right no high rpm torque converters for the dragstrip addicts, some people may actually have to learn how to drive.
Old Aug 20, 2005 | 04:55 PM
JH's Avatar
JH
Yes, you answered him, then slammed him with that nasty IQ remark. It's guys like you that can spoil ANY hobby by insulting people who don't know as much as you on the subject. You may be an ok guy but you have a steep curve around here to prove it.
Old Aug 20, 2005 | 05:06 PM
billiardcue
As previously stated I understand why GM designed the car this way. This is my second C5 A4 car so I have a preference to the automatic transmission but would like to eliminate this "little quirk" just as I eliminated the "little quirks" limiting my car to run low 13's in the 1/4 mile and pulling less than a 'G' on a skid pad. My car now runs mid 11's and has pulled over 1.1 G's on a skid pad. These are my preferences as is the ability to make second gear shift into first at WOT or from a stop.
Dick Abbott
Old Aug 20, 2005 | 06:59 PM
Cary's Avatar
Cary
I can see why your username is "lost" since your certainly lost on good manners. Evidently your not enjoying retirement
Old Aug 20, 2005 | 07:34 PM
boatboatboat's Avatar
boatboatboat
Does taking off with the gear in 2nd on an a4, cause any harm to the tranny?
Old Aug 20, 2005 | 08:55 PM
lost's Avatar
lost
Sorry if I pissed some of you off, but i've got a pulled ACL, can't work on my car , barely can walk around, so I'm not a happy camper.I know I shouldn't let my pain effect my responses on a forum and if you check my past posts you will find that I am most often polite and helpful,but the past month or so has been very difficult. Taking off in second gear will not hurt the tranny, although quite embarrassing when you do it at the strip.2.60 60 foots make for crappy times.
Old Aug 20, 2005 | 09:20 PM
Cary's Avatar
Cary
Pulled ACL? Damn, that sux. I guess you had your knee evaluated by an Orthropod, right? If so, glad your anterior cruciate ligament is not torn. A torn ACL would require surgical reconstruction. Plus, at least 4 weeks of knee immobilization, followed by passive, then active rehab for at least 6 months.
Hope your healing process goes well. BTW, your explanatory post is the first step towards recovery of your previous acts of transference.
Old Aug 21, 2005 | 12:56 AM
Dirty Howie's Avatar
Dirty Howie
I guess your not going to get any technical help to your question.
I have no use for 2nd gear starts here in southern california.
And I use the 2nd position at the track and canyon runs to keep rpms/torque high without having the tranny shift into 3rd. In those infrequent times when I get speed down too low I will either drop it into 1st or up to 3rd depending on whats ahead. If I am in total crazed out racing mode I may manually shift 1st to 2nd then to 3rd and drop down to 2nd as necessary. I don't find too may situations when I come to a complete stop in second.
I know this is not an answer just my observations as a fellow A4 inthusiast. And don't forget you gotta give up something....you don't want a M6 do ya????
DH
Old Aug 21, 2005 | 09:34 AM
boatboatboat
I wonder if the 2006 6speed auto paddle shift, can be put into a c-5?
To A4 trans 2nd gear
