Right Speaker & Door Lock Dead
Old Aug 20, 2005 | 02:17 PM
Iceman_K's Avatar
Iceman_K
Default Right Speaker & Door Lock Dead
The right front speaker on my vette just went out. Also the door lock mechanism on the right side doesn't work with the fob or button in the car. I have to manually unlock it. I've checked the fuses. Any suggestions on what I should troubleshoot next? Thanks.
Old Aug 20, 2005 | 03:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Door control module
Old Aug 20, 2005 | 03:47 PM
Iceman_K's Avatar
Iceman_K
Is the door control module difficult to install?
Old Aug 20, 2005 | 09:21 PM
screw991le's Avatar
screw991le
Not really, the inside skin comes off and it is right there
Old Aug 20, 2005 | 10:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I recommend examining all of the connectors and wiring for the door. They get a lot of abuse from vibration. There are two main door connectors that run throught the accordian tube that connects the door to the body. Remove the speaker and you will be able to find the wiring and connectors. There have been cases where the connectors were found loose and damaged.
Bill
Old Aug 22, 2005 | 09:43 AM
Iceman_K's Avatar
Iceman_K
Thanks to everyone for the advice. I will take the door apart this weekend. What kind of electrical tester do I need to determine if I'm getting juice at the speaker?
Old Aug 22, 2005 | 07:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any digital volt meter will do. Amplifier out put is just modulated voltage.
BC
Old Aug 23, 2005 | 10:25 PM
Iceman_K's Avatar
Iceman_K
I checked the connectors. They look ok. I cleaned the connectors and re-attached. It didn't seem to make a difference. The lock function usually works but, the unlock function works maybe 1 out of 6 trys. Sound like the door control module?
To Right Speaker & Door Lock Dead
