Best plug wires? MSD?
Old Aug 22, 2005 | 12:01 AM
blu00rdstr's Avatar
blu00rdstr
Default Best plug wires? MSD?
I have Taylor Thunderbolts which lasted 20K miles, but pulled a boot and the terminal, some carbon core, and a long thin wire stayed on the plug. Time to change plug wires.
What's the best plug wire for a supercharged motor (high cylinder pressure) with headers (high heat near wires)?
I did a search, and some recommend MSD. Is MSD still tops?
Edit: BTW - Best price I found is $59.95 from Scoggin Dickey
http://www.sdpc2000.com/catalog/1528...-LS1-Boots.htm
Also, is Koolsox 'required'? It's yet another $42.99 (http://www.ecklers.com/product.asp?p...761CD4F5W40844)
Thanks.
Old Aug 22, 2005 | 01:11 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Thanks.
I have the MSD wires on mine with no problem. I like them and I have no Koolsox on mine and it works just fine. I got mine at Summit Racing Equipment.
Old Aug 22, 2005 | 01:17 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
MSD's are very good.
VR
Old Aug 22, 2005 | 09:57 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Old Aug 22, 2005 | 11:59 AM
blu00rdstr's Avatar
blu00rdstr
Done - bought them. Thanks!
Old Aug 22, 2005 | 10:41 PM
vetterdstr's Avatar
vetterdstr
Old Aug 23, 2005 | 10:24 AM
jimcork1's Avatar
jimcork1
Do the MSD wires affect raido reception. Static or loss of range. Thanks 99 Nassau Blue
Old Aug 23, 2005 | 10:36 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
I have some radio static with mine, but only when the engine is loaded at low RPM. Since it rarely happens, it doesn't bother me.
Old Aug 23, 2005 | 10:51 AM
c3andc5's Avatar
c3andc5
I recently installed MSD 8.5mm Superconductor wires when I changed my plugs to the Iridiums. No EMI/RFI and no noticeable affect on reception.
Old Aug 23, 2005 | 10:53 AM
BadAV's Avatar
BadAV
I've had a set of the Superconductors on my Avalanche for almost three years. I immediately noticed a smoother idle. There is no RFI interference.
Old Aug 23, 2005 | 11:07 AM
MHVette's Avatar
MHVette
I have them and like them
Old Aug 23, 2005 | 11:40 AM
vette4540's Avatar
vette4540
done mine this past weekend, so far so good
Old Aug 23, 2005 | 12:16 PM
WKMCD's Avatar
WKMCD
VR
Old Aug 23, 2005 | 04:45 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Put mine one over a year ago and NO problems at all...
I used the old stock heat shields on the new wires as well. Not perfect but they fit "ok" and I felt the extra protection would be good...
Old Aug 23, 2005 | 06:19 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Magnecor Wires for me... LPE sells them for 60 bucks.. these are top shelf wires
Old Aug 24, 2005 | 12:04 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I had the MSD's but went back to stock due to misfires from MSD's. Since thene, 10K boosted miles with no issues.
Old Aug 24, 2005 | 12:23 AM
stano's Avatar
stano
I also had misfire codes using the MSD's that showed up on a OBDII scanner. I went back to stock wires using the koolsocks and no more misfire codes.
Callawaycars.com sells some nice wire sets...pricey but they look sweet!
To Best plug wires? MSD?
Old Aug 24, 2005 | 02:10 AM
blu00rdstr's Avatar
blu00rdstr
Of course, now that I ordered the MSDs you guys mention misfires!
...So, what causes it, too much resistance, plug gap too wide, or leaky wires?
Old Aug 24, 2005 | 03:32 PM
YLWFVR75's Avatar
YLWFVR75
Get the Magnecor's and call it a day!!!
Old Aug 24, 2005 | 04:24 PM
vette4540's Avatar
vette4540
did anyone notice a drop in gas mileage AFTER switching to MSD plugswires? I seem to have dropped from 20 to 19, driving the same to and from work each day. also switch to NGK Iridium plugs. what gives?
