jew injectors
Old Aug 22, 2005 | 07:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why do you think the injector/s are bad? There are a few ways to check them. They should read right around 14.2 ohms (took a reading on my 02 Z06 10 minutes ago) When the engine is running you should be able to take a long screwdriver and place the blade end on the injector body and the plastic end on your ear hole area and hear the injector click each time it fires. As you have someone rev the engine, the clicking should increase as rpm goes up. Each injector should sound the same. The injector firing noise should be a nice crisp click sound.
Injectors can leak or plug up. Remove the fuel rail with the injectors installed and pressureize the system. You should not see any leaks.
If your brave, you can stick each injector in a paper cup and crank the engine and watch each one spray! Not advisable but I have done it! If the spray pattern is messed up, you will see it.
My bet, the injectors are good!
BC
Old Aug 22, 2005 | 08:12 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
You know you can edit titles now right?
"My injector is giving me the Shylock on the fuel!"
Old Aug 22, 2005 | 08:20 PM
Geneus's Avatar
Geneus
Originally Posted by LS1LT1
I wasn't aware that Israel made injectors for the LSX motors, perhaps you should just stick with the OEM ones next time?
Bad joke, yes.
Actually, I think the original ones were first introduced in Germany by Dr. J. Mengele in the late 30's. (I can make that joke, being a member of the "tribe." )
Old Aug 22, 2005 | 08:28 PM
lost's Avatar
lost
The UZI 160lb injectors are awesome, not only will your car be fast it will fire 1000 rounds per minute.
Old Aug 22, 2005 | 08:31 PM
Mike Mercury's Avatar
Mike Mercury
not always. once someone responds to your thread, I don't think you can edit the main subject title.
Old Aug 22, 2005 | 09:03 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
That's what I thought also but anyway I don't drink it and it's Co FF ee I never won a spelling be either As long as we get the point what's the difference we are not teachers grading papers
Old Aug 22, 2005 | 09:31 PM
thermalracing's Avatar
thermalracing
im new to this forum site, how do i edit the title?
Old Aug 22, 2005 | 11:20 PM
bierbelly's Avatar
bierbelly
Originally Posted by thermalracing
I WAS LITTERALLY ON THE GROUND LAUGHING WHEN I REALIZED THE MISTAKE I HAD MADE!!! Sorry to anyone i might have offended. omg that was funny.
got my attention.
