Shifter Boot for Hurtst Shifter
Old Aug 22, 2005 | 11:15 AM
H20Vette's Avatar
H20Vette
Default Shifter Boot for Hurst Shifter
Does anyone know if this shifter boot fits the hurst shifter that goes in the C5? It looks like you might be able to trim the stock shifter boot/cover thingy out in the middle so that this boot could fit under it (and over the hurst base). Maybe that would seal out some noise?
http://store.summitracing.com/partde...=KeywordSearch
Old Aug 22, 2005 | 11:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I would be inclined to say maybe , however I purchased one from Vette Essentials for my car
Old Aug 22, 2005 | 11:45 AM
H20Vette's Avatar
H20Vette
Are you talking about the leather boot? I'm referring to a rubber boot that goes under the leather boot. This would be for quieting purposes only. You wouldn't see it.
Old Aug 22, 2005 | 11:46 AM
simpleman68's Avatar
simpleman68
Don't bother with buying anything new for the Hurst. You shouldn't need it.
I took the existing rubber and carefully trimmed the bottom with a razor and it now fits snug and tight and the noise is almost non-existent.
Scott
Old Aug 22, 2005 | 11:54 AM
H20Vette's Avatar
H20Vette
Scott
Thanks. There seems to be a lot of people on here who take issue with the noise. Do you think there is variation between cars or are some people just more picky than others?
Old Aug 22, 2005 | 12:29 PM
simpleman68
Noise level tolerability is different for all of us.
I just hated hearing the noises. I also noticed another weak spot is where the carpet fits under the dash/shifter plate. I found it when running wires for my new audio/dvd setup.
I'll eventually remove carpet and use the sound deadening stuff on all the floor pans etc.
Lots of work but I've heard it makes a BIG difference.
Scott
Old Aug 22, 2005 | 01:01 PM
leadfoot4's Avatar
leadfoot4
I forgot all about the OE rubber one...I just trimmed mine to fit around my Hurst.
To Shifter Boot for Hurtst Shifter
