Resetting DTC Question?
Old Aug 24, 2005 | 12:01 PM
Don Lindeman's Avatar
Don Lindeman
Default Resetting DTC Question?
When you reset DTCs using the DIC, do you reset the entire circuit, including the malfunction, or do you just reset the display?
Old Aug 25, 2005 | 12:02 PM
Silver98's Avatar
Silver98
If the DTC is a history code, resetting the DIC will clear the DTC from memory. I don't know if you can recall the DTC's with an OBDII after that, I do not believe so. If the DTC is Current, resetting the DIC will clear the code from memory until you start the Vette again, and if the condition is present, the DTC will be 'thrown' again.
Old Aug 26, 2005 | 02:50 AM
Don Lindeman
Thanks....
So if I understand this correctly, you are just resetting the DISPLAY of the DTC, but NOT resetting the actual sensing circuit that triggered the display of the DTC.
The fault itself must be fixed, or the computer will sense the fault again which in turn, will cause the DIC to diplay the DTC again. Do I have it right?
To Resetting DTC Question?
