Low Washer Fluid on 2002
Old Aug 26, 2005 | 09:38 AM
The Wanderer's Avatar
The Wanderer
Default Low Washer Fluid on 2002
Hello all…
My washer fluid low is flashing on my dash of my 02 Z06. It was low and I filled it (not immediately). I’m thinking the float (if that is what drives the signal) might have corrosion on it. I’m going to try banging on the washer container and see if it works again. Any other suggestions or ideas ?
Thanks in advance.
Old Aug 26, 2005 | 07:23 PM
Old Rotor Head's Avatar
Old Rotor Head
I'm a little late getting you a reply but looks like I'm first. Look at the back of your tank by the clutch res. You'll see a white plug. The flat side goes down, round side up. That's your float and it'll sometimes get inverted if you messing around in that area.
Old Aug 26, 2005 | 09:31 PM
BrentNY's Avatar
BrentNY
Got the same problem. Checked Bill Curlees grounds. Replaced low water switch(sensor) That didnt help. I've learned to live with it. I'll try to take a look tom. based on above post.
To Low Washer Fluid on 2002
