Kooks Header Install
Old Aug 25, 2005 | 09:42 PM
sacstyl's Avatar
sacstyl
Default Kooks Header Install
Going to install on 99 vert.What do i do with air tubes.
Old Aug 26, 2005 | 03:39 PM
sacstyl's Avatar
sacstyl
ttt
Old Aug 26, 2005 | 03:41 PM
Patches's Avatar
Patches
Hook 'em up. Do you have the later version of the Kooks and need to adapt the passenger side to make it longer? Why are you asking? Are you thinking of eliminating the AIR pump? Most just connect the AIR tubes.
Old Aug 26, 2005 | 04:49 PM
sacstyl's Avatar
sacstyl
Only the passenger side has a 1/2 " round adapter on it nothing on driver side.
Old Aug 26, 2005 | 04:57 PM
sacstyl's Avatar
sacstyl
Just went and looked at stock set up and that 1/2" adapter is for dip stick bolt.No air-tube inlets can i still use these.
Old Aug 26, 2005 | 05:20 PM
Patches's Avatar
Patches
Hmm . . . no AIR tubes. Here are a few pics of a Kooks install I helped a buddy with on his 2000 FRC which is the same setup you have. Notice the AIR tubes on each header. If you bought these used, someone cut the tubes off prior to you buying them. You can use them but you'll need to eliminate the AIR pump system using a tuner like EFILive or HP Tuners. Plus you may not pass emissions/inspection in a state that does visuals.
http://redshift.homestead.com/kooks.html
Old Aug 26, 2005 | 05:33 PM
sacstyl's Avatar
sacstyl
Great pics . Mine for sure are not like those i must have bought the race model minus air-tubes.Well i guest live and learn.
Old Aug 26, 2005 | 07:34 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Kooks makes a race system that does not have AIR tubes. If you are running the Kooks race system you are not running cats so you have no use for the AIR system. Have your tuner edit out the rear 02 sensors and the AIR codes.
Bob
Old Aug 26, 2005 | 09:32 PM
Avanti's Avatar
Avanti
For once William Shatner on the PriceLine adverts is correct... do research, THEN spend money.
All the best.
To Kooks Header Install
