What temperature does your A4 transmission run?
Old Aug 26, 2005 | 09:45 AM
Don&Kelly's Avatar
Don&Kelly
Default What temperature does your A4 transmission run?
What is the "normal" temperature that a corvette with a A4 (automatic) transmission runs in the summer??
Old Aug 26, 2005 | 11:20 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Mine rins from 150 to 160 that's with a cooler
Old Aug 26, 2005 | 11:26 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Without a seperate cooler and with a stock thermostat and no mods, it should run about the same or a little higher than your coolant temps.
Old Aug 26, 2005 | 12:37 PM
rapid robert's Avatar
rapid robert
Here are my # Oil temp 210
Trans 192
Water 187
Oil Press 43
That was 2hrs. of highway driving 90 deg. Florida weather.
Old Aug 26, 2005 | 06:08 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If you have a higher stall T/C it will run higher than normal.
Old Aug 26, 2005 | 08:09 PM
Don&Kelly's Avatar
Don&Kelly
Al, I know you used to drag alot - what size stall convertor were you using & what tranny temps did you get after several runs?
Old Aug 27, 2005 | 12:45 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
You didn't check the sig! O.K. I have a Yank ST-3500. I have never checked the temp after a run because it just to short. On the freeway, I am usually around 190 (75 deg) and in the desert around 210-215 (100 deg).
To What temperature does your A4 transmission run?
