Intermittant External Temp on Climate Control Display
Old Aug 26, 2005 | 09:54 AM
joec87's Avatar
joec87
8th Gear
Default Intermittant External Temp on Climate Control Display
Hi all,
Searched the forums but did not see anything recently on the problem I'm having. Over the past year, the climate control digital display on my '99 C5 has not always shown the correct outside temperature. When it's working it's accurate, when it's not working right it displays a temp about 20 degrees cooler than actual and it does vary a few degrees around that point. Occasionally, it will jump to the correct temp for some period of time. It has gotten worse over time to where it now rarely displays the correct temp. All other functions of the climate control system work fine. Any help is very much appreciated!
Old Aug 26, 2005 | 01:16 PM
thisMSGgood4me's Avatar
thisMSGgood4me
It's likely your external temperature sensor has gone bad. Pretty easy and cheap fix that's been talked about many times here. Do a search for external temperature sensor and you should find a writeup about how to replace.
Old Aug 29, 2005 | 10:07 AM
joec87's Avatar
joec87
8th Gear
Thanks very much for the assistance!
Old Aug 29, 2005 | 10:17 AM
98vettecpe's Avatar
98vettecpe
I have a 99 also and just purchased the sensor from a gm dealer for $7.50 and they carried it in stock [big seller!]
Old Aug 29, 2005 | 02:57 PM
jrwst39's Avatar
jrwst39
7th Gear
I had the very same problem until this past Saturday, when I replaced the ambient air temp. sensor - Problem solved. I bought the part from a local dealer for $8.75, and the install took 5 minutes.
To Intermittant External Temp on Climate Control Display
