LM-1 Install Questions
Old Aug 26, 2005 | 10:08 AM
kromberg's Avatar
kromberg
Default LM-1 Install Questions
- What ground point did you use for the RPM coverter ground wire? The manual says to ground the converter as close to the signal grounds as possible. I assume that the coverter should use the same ground point as the PCM?
- Anyone pulling the signal off the IAT sensor? If so, what wire did you splice into?
Thanks,
Keith
Old Aug 26, 2005 | 02:18 PM
T_Vert's Avatar
T_Vert
ground for the output? YOu just use a cig lighter to power it up normally
dave
Old Aug 26, 2005 | 02:31 PM
kromberg's Avatar
kromberg
dave
Ground for the accessory RPM converter module.
Keith
Old Aug 26, 2005 | 02:57 PM
T_Vert's Avatar
T_Vert
hrm, cant help ya there. For my lm1 output i just used the ground from the lm1 o2 wire. I heard you didnt need the convertor for the ls1 motors though. you could just tap into a certain wire under the steering wheel.
Dave
To LM-1 Install Questions
