Cool Radiator Water
Old Sep 1, 2005 | 04:52 PM
Tyler Dirden's Avatar
Tyler Dirden
Water Wetter works for me. Seems about 8 -10 degrees cooler on average.
Old Sep 2, 2005 | 02:00 AM
Vette_Fan's Avatar
Vette_Fan
I run 55-60% Dexcool, rest water. 1 bottle of Water Wetter, and stay at 196 - 198* normal driving. Water wetter does NOT help with Antifreeze. It will work with just plain water, which we can't use. So, its just a waste of $$$...
Old Sep 2, 2005 | 12:04 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by TheDVS1
To say that Dexcool by itself causes problems is just plain wrong....
I agree. I have had Camaros, Corvettes, and other GM cars with Dexcool, and everytime I have drained the coolant to change it, the system has been clean.
Old Sep 3, 2005 | 12:19 AM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by 6Speeder
Only true in certain cases. If you are driving at speeds higher than 45 to 50, with a 195 stat, you will run hotter than if you are running a 160.
Only true in a certain low speed cases (highway speeds) where the engine isn't putting out much energy. Between 160 and 190 the lower thermo will offer some dubious lower temps (slows temp increase thus causing more engine wear) Once the temp gets above 195 it doesn't make any difference since a 195 will be open all the way also. So if you are driving at high speeds with coolant temps of 230 you can take out the thermostat and not see any difference. It is a cooling system and once its cooling capacity is reached lower thermostats will not help.
Bill
Old Sep 6, 2005 | 10:01 AM
MHVette's Avatar
MHVette
Originally Posted by Evil-Twin
your 160 stat has "NO" effect on how hot your car gets...
I respect your opinion & agree it can and will get to 230 degrees if you sit in hot weather not moving. I've read all the threads on the t-stat and all about how need to reset the fans to obtain the optimal amount of cooling, etc as well. I can tell you only what my coolant temps are on my coup after I changed the t-stat out and it does run consistently lower temps while traveling... If the cars starts to get warm I turn on the A/C and both the Vette & I cool down!
Old Sep 6, 2005 | 12:42 PM
M_T_0's Avatar
M_T_0
on a 98 mI would check for a buildup of junk between the a/c condensor and the radiator. just took mine off (99) and about 15% of the area was cloged.
next I would program the fans to come on at a lower temp say 5-10 deg above the tstat and the secondarys at 10-20 deg above the tstat.
the water wetter is a good product but it is not as effective on the corvette with the 50/50 antifreeze solution, you could change to 25/75
and then water wetter and pick up a little depending on your winter weather.
More Than Zero
Old Sep 6, 2005 | 02:04 PM
fixvet's Avatar
fixvet
