Evans Coolant?
Old Aug 26, 2005 | 05:40 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Evans Coolant?
Is Evans coolant worth the 40.00 a gallon?
What is its advantage over Dex-cool
Old Aug 26, 2005 | 08:31 PM
ICULUKN-C5's Avatar
ICULUKN-C5
ttt
Old Aug 26, 2005 | 09:26 PM
BrentNY's Avatar
BrentNY
Wow. $40.00 bucks. I never heard of it. Whats the web site say. I would buy it if they could promise me 10 degrees.
Old Aug 26, 2005 | 09:32 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
Evans is the best name in cooling, it is worth every penny!
AZC5
Old Aug 26, 2005 | 09:50 PM
2KREDVert's Avatar
2KREDVert
Get rid of the Dexcool. Lots of lawsuites against GM for excessive corrosion. Type in Dexcool lawsuites in your search engine and read a ton of complaints.
Old Aug 26, 2005 | 10:32 PM
LoneStarFRC's Avatar
LoneStarFRC
Anyone can sue for anything. Suing doesn't make it so. I have 110K miles on my stock water pump. I'm now on my second load of DexCool and no corrosion problems at all. Do proper maintenance, change hoses every four or five years, etc and your stock cooling system will work just fine with DexCool.
Evans Cooling Products have been around for several years and are gaining a very good reputation. When you use their coolant, you use no water with it. Go to their website and check it out.
Old Aug 26, 2005 | 10:58 PM
2KREDVert's Avatar
2KREDVert
[QUOTE=LoneStarFRC]Anyone can sue for anything. Suing doesn't make it so. I have 110K miles on my stock water pump. I'm now on my second load of DexCool and no corrosion problems at all. Do proper maintenance, change hoses every four or five years, etc and your stock cooling system will work just fine with DexCool.
QUOTE]
I have talked to several auto machinists, radiator people and mechanics about Dexcool. They all call it Deathcool. I think it is ok until your system gets some air in it, then it acts like a cancer and corrodes like crazy. Ask any professional radiator guy or machinist, they will give you an earfull on Deathcool.
Old Aug 26, 2005 | 11:30 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
If it's so bad, what do they recommend using? I'd say any coolant would be a problem if the system has air in it or plain tap water is used.
Old Aug 27, 2005 | 06:31 PM
LoneStarFRC
[QUOTE=2KREDVert]
Originally Posted by LoneStarFRC
Anyone can sue for anything. Suing doesn't make it so. I have 110K miles on my stock water pump. I'm now on my second load of DexCool and no corrosion problems at all. Do proper maintenance, change hoses every four or five years, etc and your stock cooling system will work just fine with Dex-Cool.
QUOTE]
I don't know of any definitive proof regarding air and Dex-Cool being mutually exclusive. Air, in enough quantity, will cause a problem in any cooling system eventually. Mainly from it's lack of ability to transfer heat. Not from any interactivity with coolant products.
And exactly how does any system get air into it? Not doing periodic checking and/or maintenance? Usually.
Speaking of "professional radiator guy", I was once told by a very very well known radiator shop man here in Houston (large well regarded shop), that distilled water does not cool as well as tap water, since tap water has minerals in it that and therefore it cools better. Puhleeez!
Point is, opinions regarding anti-freeze/coolants are many times all over the map. If the horror stories being told were all so true, I would have had to replace my entire engine and radiator by now.
I'm speaking from personal experience on my C5. Dex-Cool has not been been a problem at all.
To Evans Coolant?
