Air Tubes
Old Aug 26, 2005 | 07:02 PM
sacstyl's Avatar
sacstyl
Default Air Tubes
Is ok to plug off air-tubes then edit out error codes.What is the purpose of the air-tubes.Will this effect anything.Got a great deal on Kooks system but was unaware that they were minus air-tube.
Old Aug 26, 2005 | 07:31 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Air tubes are there for the air pump to aid in lighting off the cats. If you are not using cats you can edit out the rear 02 sensors and the air codes.
Bob
Old Aug 26, 2005 | 09:00 PM
sacstyl's Avatar
sacstyl
System Came with cats & X-pipe can i use them to quiet it down a bit and still edit out O-2 sensor.
Old Aug 26, 2005 | 09:05 PM
16Again's Avatar
16Again
You can edit out the rears. If your not using the AIR system those codes will need to be edited out as well. I'm not sure what will happen with the cats though as this is an odd set-up. Wish I could be of more help.
To Air Tubes
