Battery tender question
Old Aug 29, 2005 | 12:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Battery tender question
I purchased a deltran waterproof 800, the light shows and battery is always charging and never full. Does that mean the battery is going south.
The car starts everytime, even after weeks of sitting, but I added the charger for added protection and I can't help myself from buying stuff.
The light never shows full/trickle, is that a problem, does anyone else have that issue?
Old Aug 29, 2005 | 04:41 PM
FKING1's Avatar
FKING1
My Batery Tender always goes to the green light stand by setting after a couple hours. What does your instructions say? IMO it should go to trickle.
Fred
Old Aug 29, 2005 | 04:43 PM
screw991le's Avatar
screw991le
The direction say, yellow for charging and green for trickle/charged.
It is this one, from Deltran
Old Aug 29, 2005 | 09:37 PM
davette's Avatar
davette
Charge up your battery first with a real battery charger and then see if the "trickle" charger holds the full charge. If not, your battery is going south..... Your trickle charger isn't mean't to recharge a low battery, only to keep it fully charged while not in use.
Old Aug 29, 2005 | 10:10 PM
screw991le's Avatar
screw991le
OK, battery recomendations, if I need a new one? Red top?
Old Aug 29, 2005 | 11:38 PM
davette's Avatar
davette
Alot of people will tell you, Red top not worth the price. Not any better than a standard battery. The newer GM batteries are good for the money...
Old Aug 30, 2005 | 11:20 AM
GUSTO14's Avatar
GUSTO14
Default Exide Orbital
Exide makes an AGM battery called the Orbital
-features a highly efficient design of spiral-wound plates combined with absorbed glass mat lead-
http://www.exideworld.com/products/...rbital_XCD.html
It's an excellent battery looks a bit more like your original Delco, and costs about the same as an Optima... I've had great service from mine even with extended periods of non-use.
GUSTO
Old Aug 30, 2005 | 12:11 PM
screw991le's Avatar
screw991le
To Battery tender question
