PCM Ground Location
Old Aug 29, 2005 | 03:13 PM
kromberg's Avatar
kromberg
Default PCM Ground Location
Where is the spot that the PCM is grounded to? I also assume that all the sensors are grounded through that same spot right?
Keith
Old Aug 29, 2005 | 03:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! There are numerous locations where grounds are located! The PCM is actually grounded in more than one location. Here is a post that I started a while back that has a lot of electrical info and a list of ground locations.
http://forums.corvetteforum.com/show...ion&forum_id=1
I will look up the exact PCM ground locations when I get home later tonight.
What problems are you having that you think is being caused by bad PCM grounds??
BC
Old Aug 29, 2005 | 04:00 PM
kromberg's Avatar
kromberg
I am not really having problems, I am finishing up the install of my LM-1 wideband O2 reader with accessory signal recorder. I would like to record the MAP and IAT signals. The accessory reader needs to be grounded to the same ground point as the sensors or as close as possible. I assume that all the sensors where grounded through the PCM and it was grounded in a single location.
Keith
Old Aug 29, 2005 | 06:28 PM
STA-BLK's Avatar
STA-BLK
Old Aug 29, 2005 | 09:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Keith
A good place to ground the sensor should be at point# 9 on the diagram. That is where the battery grounds to the frame. Here is a picture of it:
Easy access and a good ground point!
Bill C
To PCM Ground Location
