Datalogging At The Track
Old Aug 29, 2005 | 08:08 PM
INTHERED's Avatar
INTHERED
Default Datalogging At The Track
I have a Predator that I use as a scan tool but it does not have a record function plus my car is getting too fast to look at a Predator display while traveling down the quarter mile. Are there any cheaper datalogging solutions that plug into the ODBII port record engine parameters like spark advance, Knock retard, rpm, etc. that do not require a laptop to be present in the car. I would like to hit a button run down the track and then playback the data on my PC when I return home. Any ideas ?
Thanks >>>> INTHERED
Old Aug 29, 2005 | 08:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I use Auto Enginuity, works very well and has data logging and dyno sim. $100 on e-bay and works on all OBD-II cars
Old Aug 29, 2005 | 09:56 PM
INTHERED's Avatar
INTHERED
Does the Auto Enginuity package have built in memory that records the data so it can be played back later or do I need a palm or laptop ?
Thanks >>>>> INTHERED
Old Aug 29, 2005 | 10:09 PM
screw991le's Avatar
screw991le
You need the laptop to record the info.
CHeck out the e-bay and then visit their site
To Datalogging At The Track
