Help with rt front turn signal/running light
Old Aug 29, 2005 | 09:38 PM
ragtop00's Avatar
ragtop00
Default Help with rt front turn signal/running light
How do you change rt front turn signal/running light. 2000 c5 vert A4.
Old Aug 29, 2005 | 09:41 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the ts is on a spring and can be pushed in or from the cover underneath the car
Old Aug 30, 2005 | 12:14 AM
coast7's Avatar
coast7
I was able to snake my arm down through the engine compartment to reach the light bulb socket. You need to turn the bulb CCW about 1/4 turn to get it out of its socket, then detach the bulb from the connector. Have your replacement bulb pre-positioned next to the old bulb so you don't have to snake your arm in twice.
Good luck...it's tight and will probably cost you some skin
Old Aug 30, 2005 | 08:39 AM
ragtop00's Avatar
ragtop00
Thanks, I'll give it a try and post my success/ failure and blood loss stats.
Old Aug 30, 2005 | 01:08 PM
77BlueL82's Avatar
77BlueL82
Default Replacement
I opened the head lights, then I took out the front hood adjustment screw. This made alot more room to put my hand and arm in. I changed them both in less than 10 minutes.
Old Sep 13, 2005 | 09:10 AM
ragtop00's Avatar
ragtop00
Thanks for the tips guys! I removed the front hood adjuster and it was easy.
Old Sep 13, 2005 | 12:49 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Did you have any problems geting the bulb/socket back into the lens?It took me quite a while to get mine in and I still don't know what the trick is.
To Help with rt front turn signal/running light
